Solving Gauss' Law: Find Flux of 443C Ball with 7.97cm Radius
The discussion revolves around applying Gauss' Law to determine the electric flux through the surface of a sphere surrounding a point charge of 443 C. The radius of the sphere is given as 7.97 cm. Participants are exploring how to correctly use Gauss' Law to arrive at the expected answer.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss various equations related to Gauss' Law, questioning which specific form to use for a point charge. Some express confusion over the calculations and the expected results, while others suggest reviewing the assumptions about the charge and the equations used.
There is an ongoing exploration of different interpretations of Gauss' Law and its application to the problem. Some participants have provided guidance on the equations to consider, while others are still seeking clarity on their calculations and the relevance of the sphere's radius.
Participants note discrepancies in the answers provided by the source website, leading to questions about the accuracy of the information and the equations being used. There is a recognition that the radius may not be necessary for the calculations, but this remains a point of contention.
delongk
How would you solve this:
A small charge of 443 C is at the center of a 7.97 cm radius ball. How much flux passes through the ball's surface?
The answer is 4.922 E-8 N.m2/C
I don't know how to get this answer. Please explain. Thank you!
You wrote the title as "Gauss Law Question". Do you know what Gauss' law says? Can you apply it here?
I know it is Gauss' Law because that is what the website I got it from said. I have looked everywhere and applied the Gauss' Law how I thought I should apply it but I keep getting the wrong answer and have no idea how they got that answer. So that is why I need someone to explain it for me if they know.
Perhaps if you showed your working we could point out where you have gone wrong...
Well, I am confused as to what Gauss Equation to use... I have tried q=Eo*flux and then I tried flux=q/4pi*k and then I tried flux=k*q/r^2... none of them turn out correct.
What is the equation to use for a point charge in a sphere?
I keep finding that flux= q/Eo and so I put 443 in for q and 8.85*10^-12 for Eo and get 5.006*10^13.
Assuming that you are familiar with calculus, you can have a look at http://en.wikipedia.org/wiki/Gauss_law. The flux is indeed [itex]q/\epsilon_{0}[/itex] in your case :smile: Do you have a doubt about the flux being independent of [itex]R[/itex]? If so, the wiki article/a reading from any standard textbook should clear it.
443 C, is an awful lot of charge. Are you sure you got the numbers right from the question?
You calculated the flux as q_enc/Eo, and that should work.
I copied and pasted it so I know that is right. And I keep getting the wrong answer for ALL of the examples... which are all similar to that one.
Another example on the webpage is:
A small charge is at the center of a 9.77 cm radius ball. If 8.322 E-8 N.m2/C passes through the ball's surface, how much charge is at the center?
and the answer is 749C.
I don't get this one either. I am assuming the use the same equation.
Ok, Gauss' law is
[tex]\int \vec{E}.d\vec{a} = \frac{q_{enc}}{\epsilon_0}[/tex]
That's the equation you're going to use for these problems.
Now, note that
(i) The value of [itex]\int \vec{E}.d\vec{a}[/itex] is the flux passing through the surface.
(ii) Using Gauss' law, it follows from the previous step that [itex]\frac{q_{enc}}{\epsilon_0}[/itex] is also the flux passing through the surface.
So, you've got 2 ways to calculate the flux.
Why have they given the radius? Because you can calculate the area of the ball. Notice that, when a charge is at the center of a sphere, the integral [itex]\int \vec{E}.d\vec{a}[/itex] can be simply reduced to E times A. Can you figure out why, and solve the problems from here?
no i have no idea what to do... i need step by step. and everything i read said you don't need the radius.
I think the problem is that whoever calculated the answers on that site is incorrectly using the Coloumb force constant {1/(4*Pi*epsilon_0)} instead of the permittivity of free space (epsilon_0) in their calculations. For instance, they ask this question:
"A small charge of 45 C is at the center of a ball. If 5 E-9 N.m2/C passes through the ball's surface, what is the radius of the ball (if it matters)? "
Now, obviously for that question the answer is that the radius doesn't matter, but if you use their values for charge and the flux, and plug into Flux = charge/k, solving for k you get 9x10^9, which is 1/(4*Pi*epsilon_0), not epsilon_0.
Also, if in the original question you asked, if you say Flux = 443/(9x10^9), you'll find you get their answer.
So, you were doing everything correctly; it's the website that is wrong.
  • · Replies 26 ·
  • · Replies 30 ·
