How is the Legendre transform defined in cases where g(p) equals 0?
  • Context: Graduate
  • Thread starter Thread starter eljose
    Legendre Transform
The Legendre transform is defined for a function f(r) with variables r=x,y,z and its transform g(p) with p=p_x, p_y, p_z. The equality Df(r)=(Dg(p))^{-1} is problematic when g(p)=0, as a zero matrix lacks an inverse. This issue arises in various Hamiltonians within the context of relativity and Quantum Field Theory, particularly when dealing with the Lagrangian density L=√(-g)R, where g is the determinant of the metric and R is the Ricci scalar. The Legendre transform in Quantum gravity is expressed as H=π_ab·dot g_ab - L, with the metric defined as g_ab=N(t)dt²-g_ij dxⁱdxʲ, where N(t) serves as a lapse function.
  • Understanding of Legendre transforms in mathematical physics
  • Familiarity with differential operators and their inverses
  • Knowledge of Quantum Field Theory and Lagrangian mechanics
  • Basic concepts of general relativity, including metric tensors and Ricci scalar
  • Study the properties of differential operators and their inverses in mathematical physics
  • Explore the implications of zero Legendre transforms in Quantum Field Theory
  • Learn about the role of lapse functions in general relativity
  • Investigate Hamiltonian mechanics and its applications in Quantum gravity
Physicists, mathematicians, and students specializing in theoretical physics, particularly those focused on Quantum Field Theory and general relativity.
eljose
Legendre transform...
If we define a function f(r) with r=x,y,z,... and its Legnedre transform
g(p) with [tex]p=p_x ,p_y,p_z,...[/tex] then we would have the equality:
[tex]Df(r)=(Dg(p))^{-1}[/tex] (1) where D is a differential operator..the
problem is..what happens when g(p)=0?...(this problem is usually found in several Hamiltonians of relativity) then (1) makes no sense since a 0 matrix would have no inverse..how do you define Legendre transform then...:frown: :frown:
I don't see any problem with "defining the Legendre transform", just defining its inverse- which does not necessarily exist. What kind of functions, f, and p, give g(p)= 0? Why does that not have an inverse?
The problem of Zero Legendre-transform arises for example in Quantum Field theory...let be the "Lagrangian density":
[tex]L= \sqrt (-g)R[/tex] where g is the determinant of the "metric" and R is Ricci scalar?...of course if we use a "dot" to indicate derivative respect to time we have that:
[tex]L=L(g_ab , \dot g_ab,x,y,z)[/tex] now we definte the "momenta"..
[tex]\pi _ab =\frac{ \partial L}{\partial \dot g_ab)[/tex]
then the Legendre transform for Quantum gravity is defined by:
[tex]H=\pi _ab \dot g_ab -L[/tex] where the metric is given by:
[tex]g_ab =N(t)dt^{2}-g_ ij dx^{i}dx^{j}[/tex] i,j=1,2,3 (einstein sum convention)
where N(t) is somehow a "lapse" function with a physical meaning so you get the "constraint"..
[tex]H=0[/tex]
  • · Replies 18 ·
13K
