| Thread Closed |
mass kept over a spring |
Share Thread | Thread Tools |
| Jul10-06, 04:00 AM | #1 |
when a mass(mg) is kept over a spring according to statics the spring will deform till the force supplied by the spring(kx) is equal to mg.
But when thought carefully even when the mass descends by some distance(x) when the equilibrium is reached,the mass must have acquired some velocity and it will continue to move downwards till the velocity is zero. is my thinking correct . So this is not a static problem |
| Jul10-06, 04:25 AM | #2 |
| Jul10-06, 06:31 AM | #3 |
Of course, in a real spring, there will be friction which will fairly quickly bring the motion to a stop.
By the way, if the mass is m, the "weight" or force downward on the spring will be -mg and the spring will be compressed until -kx= -mg (k is the spring constant) or x= mg/k. The equation of motion of the spring is [tex]m\frac{d^2 x}{dt^2}= -kx- mg[/tex] where x is measured from the "rest position" of the spring without force on it. If we let y= x- m/k, then the equation becomes [tex]m\frac{d^2 y}{dt^2}= -k(y+ mg/k)- mg= -ky[/tex] In other words, we can always ignore gravity if we use the "rest position" of the spring with gravity as our 0 position. |
| Jul10-06, 08:20 AM | #4 |
Mentor
| Thread Closed |
| Thread Tools | |
Similar Threads for: mass kept over a spring
| Mass on a Spring | Introductory Physics Homework | 1 | ||
| Mass and Spring | Introductory Physics Homework | 2 | ||
| Mass of a spring | Introductory Physics Homework | 4 | ||
| A Spring with mass | Advanced Physics Homework | 1 | ||
| Mass on Spring | Introductory Physics Homework | 3 | ||
