Cosine Fourier seires of cosh(t-1)
  • Thread starter Thread starter Benny
    Cosine Fourier
The cosine Fourier series for the function f(t) = cosh(t-1) over the interval [0, 1] is expressed as cosh(t - 1) = sinh(1)[1 + 2∑(n=1 to ∞) (cos(nπt)/(n²π² + 1))]. By setting t = 0, the sum ∑(n=1 to ∞) (1/(n²π² + 1)) is derived, equating to 1/(e² - 1). The discussion focuses on calculating the sums over odd and even n, ultimately leading to the correct expression for the sum over even n as (3 - e)/(4(e - 1)), revealing an initial transposition error in the calculations.
  • Understanding of Fourier series, specifically cosine Fourier series.
  • Familiarity with hyperbolic functions, particularly cosh and sinh.
  • Knowledge of convergence of infinite series.
  • Basic calculus, including summation techniques and manipulation of series.
  • Study the properties of cosine Fourier series in depth.
  • Learn about hyperbolic functions and their applications in Fourier analysis.
  • Explore techniques for evaluating infinite series, focusing on convergence criteria.
  • Investigate common errors in Fourier series calculations and how to avoid them.
Mathematicians, physics students, and engineers interested in Fourier analysis, particularly those working with hyperbolic functions and infinite series summation.
Benny
Hi, can someone give me some help with the following?
The cosine Fourier series of period 2 for the function f(t) that takes the form f(t) = cosh(t-1) in the range [itex]0 \le t \le 1[/itex] is
[tex] \cosh \left( {t - 1} \right) = \sinh \left( 1 \right)\left[ {1 + 2\sum\limits_{n = 1}^\infty {\frac{{\cos \left( {n\pi t} \right)}}{{n^2 \pi ^2 + 1}}} } \right][/tex]
Setting t = 0 yields
[tex]\sum\limits_{n = 1}^\infty {\frac{1}{{n^2 \pi ^2 + 1}}} = \frac{1}{{e^2 - 1}}[/tex]...(1)
I need to deduce the values of the sum [tex]\sum\limits_{}^{} {\left( {n^2 \pi ^2 + 1} \right)^{ - 1} }[/tex] over odd n and even n.
I tried setting t = 1 so that I could evaluate the sum
[tex] \sum\limits_{n = 1}^\infty {\frac{{\left( { - 1} \right)^n }}{{n^2 \pi ^2 + 1}}} [/tex]...(2)
Once I did that, I added (2) to (1) and it looked like I would end up with just twice the sum of the even terms since the odd terms cancel. But that's not right since I don't get the correct answer when I divide the result by 2. Can someone suggest a way to do calculate the sum over odd n and over even n? Thanks.
Certainly sounds like it should work. What did you get (2) equal to and what did you get for the sum of even terms? Since you say "I didn't get the correct answer" I assume you have an answer key. What is the "correct answer"?
I found that
[tex] \sum\limits_{n = 1}^\infty {\frac{{\left( { - 1} \right)^n }}{{1 + \pi ^2 n^2 }}} = \frac{e}{{e^2 - 1}} - \frac{1}{2}[/tex]
So that the required sum (over even n) as I thought it would be is:
[tex] \frac{1}{2}\left[ {\sum\limits_{n = 1}^\infty {\frac{{\left( { - 1} \right)^n }}{{1 + \pi ^2 n^2 }}} + \sum\limits_{n = 1}^\infty {\frac{1}{{1 + \pi ^2 n^2 }}} } \right][/tex]
[tex] = \frac{1}{2}\left[ {\frac{e}{{e^2 - 1}} - \frac{1}{2} + \frac{1}{{e^2 - 1}}} \right][/tex]
[tex] = \frac{1}{2}\left[ {\frac{1}{{e - 1}} - \frac{1}{2}} \right][/tex]
[tex] = \frac{1}{2}\left( {\frac{{3 - e}}{{2\left( {e - 1} \right)}}} \right)[/tex]
[tex] = \frac{{3 - e}}{{4\left( {e - 1} \right)}}[/tex]
which is the given answer for the sum over even n. It looks like a made a transposition error (forgot about a "+1") after I susbtituted t = 1 in the Fourier series. Thanks for the help.
  • · Replies 16 ·
