Factorization for x^3 - 4x^2 -x = 0
  • Thread starter Thread starter teng125
    Factorization
The discussion revolves around the factorization of the polynomial equation x^3 - 4x^2 - x = 0, with participants exploring the identification of roots and the relationship to a matrix's eigenvalues.
  • Mixed
  • The original poster attempts to find roots of the polynomial by dividing it by (x-1) and expresses difficulty in finding the remaining roots. Some participants question the validity of the identified root and suggest that 0 might be a root instead. Others point out potential errors in the equation provided and discuss the characteristic equation related to a matrix.
The discussion includes various interpretations of the polynomial and its roots, with some participants offering corrections and alternative approaches. There is no explicit consensus on the correct equation or the roots, but guidance has been provided regarding the characteristic equation and the quadratic formula.
Participants are navigating potential errors in the original equation and its roots, as well as the connection to eigenvalues of a matrix. The discussion reflects uncertainty regarding the correct formulation of the problem.
teng125
for x^3 - 4x^2 -x = 0 , i have found one of the root which is 1 by dividing this equation by (x-1).
from there onwards i can't do already to find the other two roots.somebody pls help
thanx
1 is not a root, 0 is. Unless you have posted the wrong equation.
sorry.the matrix is [1 2 1;2 1 1;1 1 2].so i want to find the eigenvalues
therefore i got the eqn x^3 - 4x^2 -x = 0
fine, but 1 is still not a root (1-4-1 is not zero)
The characteristic equation for the matrix you give is x^3- 4x^2- x+ 4=0
not what you give. That equation does have 1 as a root so apparently you just wrote the equation wrong (twice!).
You say you found that 1 was a root "by dividing this equation by (x-1)" (Which makes me wonder why you chose x-1. It's simpler just to set x= 1 in the equation!). When you did that surely you found that
x^3- 4x^2- x+ 4= (x-1)(x^2- 3x- 4). Solve x^2- 3x- 4= 0. That factors easily but even it it didn't you could use the quadratic formula.
If you find the quadratic formula eerie, recognize that (1,1,1) is an eigenvector of your matrix.
oooo...okok thanks very much
  • · Replies 18 ·
