Solving Bungee Jump Problem with No Air Resistance or Damping
The problem involves a bungee jumper standing on a bridge 100m above a valley floor, attached to a 25m bungee rope. The jumper has a mass of 60kg, and the scenario assumes no air resistance or damping in the rope. The objective is to determine the minimum spring constant k required to prevent the jumper from hitting the valley floor.
  • Participants discuss the energy conservation principles involved, questioning the potential energy stored in the rope during the jumper's fall. There is confusion regarding the rope's slack state during the initial fall and the maximum extension of the rope.
The discussion includes various attempts to apply energy conservation equations, with some participants providing calculations and others seeking clarification on specific steps. There is an acknowledgment of confusion regarding the mechanics of the problem, but no explicit consensus has been reached.
Participants are working under the constraints of the problem's assumptions, including neglecting air resistance and the weight of the bungee rope. The lack of clarity on the rope's behavior during the initial fall is a point of contention.
dopey9
a bungee jumper stnd on a bridge of 100m above the floor of a valley.
She is attached to a bungee rope of length 25m and has a mass of 60kg. and i have taken g to be 10
there's no: air resistance
damping in the bungee rope
and the weight of the bungee rope is negliable
i need to find the minimum required value for the spring constant k if she is to avoid hiting the valley floor
im using 1/2kx^2=mgh...but I am getting confused in what I am doing i don't know where to go next..i was wondering if i am doing it right n what i should do next ?...thankz
Your on the right track, but what happens when the binjee jumper falls the first 25m? Will the rope be storing potential energy then? What is the maximum extension the rope can undergoe without the jumper hitting the floor?
confused
sorry I am really confused?
Remember that for the first 25 meters of falling, the rope is SLACK and there is no tension in it.
my calculation
this is what i did
mgh= 0.5*k*(h-l)^2
60*10*100=0.5*k*(100-25)^2
k= 21.3
this is what i did and got k as ...have i done it right because I am so confused
Okay, for clarity I'll take this step by step:
Consider the moment when the jumper has fallen [itex]h=25[/itex] meters.
Then, obviously, the kinetic energy gain equals the loss of potential energy:
[tex]\frac{1}{2}mv_{0}^{2}=mgh[/tex]
We now look at conservation of mechanical energy during the phase where the rope stretches, and where L is the maximal length the rope stretches:
[tex]\frac{1}{2}mv_{0}^{2}=\frac{1}{2}kL^{2}-mgL[/tex]
which can be rewritten as
[tex]mg(h+L)=\frac{1}{2}kL^{2}[/tex]
with h=25, L=75, you get your own equation, so yes, you did the problem right!:smile:
thankz
Thankz .
  • · Replies 26 ·
  • · Replies 28 ·
  • · Replies 16 ·
