How Can Approximations by Expansion Simplify Scientific Calculations?
  • Context: Undergrad
  • Thread starter Thread starter eep
    Expansion
The discussion revolves around the use of approximations by expansion, particularly in the context of scientific calculations. Participants explore various methods of expanding expressions, such as Taylor series, to simplify complex calculations and discuss the implications of these expansions in theoretical frameworks like special relativity.
  • One participant introduces the concept of approximations through expansions, specifically mentioning the expression for momentum in special relativity and its simplification for small velocities.
  • Another participant explains the Taylor series and its convergence properties, providing a mathematical framework for understanding how expansions work, particularly in relation to the function f(x) = (1+x)^r.
  • A participant questions the sign in the expansion, suggesting it should be negative for odd terms, which leads to a clarification about the multiplication of negative signs in the original expression.
  • There is a mention of Fourier series as another type of expansion, although details on its application are not elaborated upon.
Participants express differing views on the sign of terms in the expansion, indicating a lack of consensus on this specific point. The broader discussion on the utility of expansions remains exploratory without definitive conclusions.
The discussion includes assumptions about the conditions under which the expansions are valid, such as the requirement for small velocities in the context of special relativity. There is also an acknowledgment of the radius of convergence for power series, which remains an unresolved aspect of the discussion.
This discussion may be of interest to those studying mathematical methods in physics, particularly in relation to approximations and expansions in scientific calculations.
eep
Hi,
I've never really studied various ways of expanding expressions in order to obtain an approximation that can make calculations easier. For example,
[tex] p^t = \frac{m}{\sqrt{1 - v^2}}[/tex]
reduces to
[tex] p^t = m + \frac{1}{2}mv^2 + ...[/tex]
for v << 1.
How does one arrive at something like this? What other expansions are useful? I used to think that I'd just calculate everything exactly but I now realize these sorts of expansions are extremeley important.
Are you familiar with Taylor series? It says that if a function can be expanded in a power series, then it will be of the form
[tex]f(x) = \sum_{n=0}^{\infty} \frac{f^{(n)}(0)}{n!}x^n[/tex]
Wheter this series converges towards the original function is another matter. (Actually, it is a matter of calculating the radius of convergence of a power series)
For exemple, the function [itex]f(x) = (1+x)^r[/itex] where r is any real number has as its Taylor expansion
[tex]\sum_{n=0}^{\infty} \frac{r(r-1)...(r-n+1)}{n!}x^n[/tex]
and the series converges to [itex]f(x) = (1+x)^r[/itex] for all |x|<1 but not for any other value of x.
This is exactly what has been done in your post. [itex]p(v)=m(1+v^2)^{-1/2}[/itex] is of the form [itex](1+x)^r[/itex] with x=-v² and r=-½, so it converges to the series expansion you wrote for all values of v such that |v²|<1.
N.B. in the context of special relativity, v is always lesser than 1 since it has been assumed that c=1, so the formula really is valid for all velocity.The only other expansion I know of is the expansion in a Fourier series.
Btw, wouldn't it be
[tex] p = m - \frac{1}{2}mv^2 + ...[/tex]
instead? (with a "-" sign instead of a "+" sign on odd terms)
The sign is +. It results from multiplying two - signs, -1/2 and -v2.
  • · Replies 24 ·
  • · Replies 19 ·
  • · Replies 16 ·
