Fountains before electric pumps
  • Thread starter Thread starter bobbobwhite
    Electric Pumps
The discussion centers on the operation of large fountains in cities like Paris before the introduction of electric pumps. Participants explore the mechanisms that allowed these fountains to function effectively, particularly focusing on gravity pressure and the use of aqueducts and artesian wells.
  • One participant inquires about the methods used to generate sufficient water pressure for fountains in cities without nearby higher elevation water sources, suggesting the possibility of distant aqueduct systems.
  • Another participant mentions artesian wells as a potential source of water pressure for fountains, explaining the difference between regular and artesian wells.
  • A participant proposes that the adequate slope of aqueducts, along with adjustments in pipe diameter, could provide the necessary pressure for fountains, seeking feedback on this hypothesis.
  • Concerns are raised about the complexity of testing the proposed ideas due to numerous variables affecting water flow and pressure, such as slope and friction.
  • Another participant argues that ancient cultures successfully developed similar systems under varying conditions, suggesting that the basic principles of these systems are robust.
  • A participant highlights the engineering prowess of the Romans, noting that some of their fountains are still operational today.
Participants express various hypotheses regarding the operation of fountains, with no consensus reached on the specific mechanisms or methods used historically. The discussion remains open-ended with multiple competing views.
Participants acknowledge limitations in their understanding due to the complexity of the systems involved and the numerous variables that could affect water pressure and flow.
bobbobwhite
Paris has many large and impressive fountains, as do many large cities sited on mostly flat topography, and I would like to know how these fountains operated so impressively before the advent of electric pumps? I understand gravity pressure concepts such the one used in the Hearst Castle water system, but how did early Paris and other cities provide enough pressure for their magnificant fountains when a higher elevation source for gravity pressure was nowhere near the city? Did they actually have very distant, higher elevation water sources and an extensive aqueduct system providing enough fall for the necessary pressure?
Thanks for informed answers only, please, not guesses.
Welcome to PF, Bobbobwhite. I don't have a lot of time for research right now, but here's a starter for you.
http://www.diplomatie.gouv.fr/label_France/52/gb/16.html"
Artesian wells can also be used to make fountains before pumps. Basically, if you drill into an aquifer directly below you, you get a reguar well, If you drill through into a pressurized aquifer, you get an artesian well.
http://ga.water.usgs.gov/edu/gwartesian.html
Okay... I've had time to dig around a bit more. Here are a few of the other links that I found. Some are pretty shallow, most are quite good, and one absolutely made my head spin.
http://www.saudiaramcoworld.com/issue/200603/the.art.and.science.of.water.htm
http://www.itia.ntua.gr/getfile/534/2/2002BESTAncGreeceHydraulWorksSM.pdf
http://www.plumbingengineer.com/pdf/pe/articles/0301PE45.PDF
http://eprint.uq.edu.au/archive/00002959/01/Nihon98_1.pdf
http://www2.brgm.fr/aih/fichier/actes/journeededarcy_a.pdf
http://eprint.uq.edu.au/archive/00000374/01/topic_2.html
http://www.bondy.ird.fr/pleins_textes/pleins_textes_6/b_fdi_49-50/010017738.pdf
http://www.cyprus.gov.cy/moa/wdd/WDD.nsf/booklets_en/BE6136FA65CFE182C2256E5B005539BA/$file/Page%201-24%20(1,96%20MB).pdf
http://www.itia.ntua.gr/getfile/539/2/2002Encycl2WatResTechAncGreEntry1a.pdf
Thanks for all the imput. I will hazard an answer myself from the material sent by DANGER. I am 99% sure that it's the adequate slope of the long aqueducts that provides ample water pressure for all those Parisian fountains, along with decreasing the diameter/size of the supply pipe over areas with no slope and decreasing it once again as the water gets closer to the fountains. Any comments?
Sounds good to me. Why don't you get yourself some boards and pipes and whatnot and build a few simple models to see what happens?
Danger,
I really don't think any test I could do would help, as I don't think I could control the many variables well enough to make the test valid. Variables such as slope, friction( a small test pipe that I would have to use would have much greater friction than would the large conduits actually used in the aquaducts for the water volume carried.), materials, curves and curve radius, elevation variances, distance, number of supplied outlets, etc. Just way too many. I think I know the answer to my question, but I still would like confirmation. Thanks for your continued efforts and if you find the precise answer, I would appreciate the info.
Richard
While I understand your reluctance to tackle all of the variables, I don't think that you realize how forgiving such systems are. Since many ancient cultures (Romans, various arabs, Turks, etc.) independently developed them in varying geological conditions with varying materials, the basic principles cover a pretty wide spectrum.
Anyhow, I wasn't suggesting that you build a scale model of Paris in your back yard (although that would nicely weird out your neighbours :devil: ). Something that would fit on a tabletop, using stuff like 1/2" channel aluminum would be sufficient to give you a 'feel' for it.
As e-mailed, I'll try to investigate more when time allows.
The Romans did it with aqueducts and sumps. darn fine engineers those people were since some of the fountains are STILL running! Gotta love the History channel!
9K
10K
37K
