Problem to find angular velocity
The discussion revolves around a particle undergoing uniform circular motion (UCM) and involves changes in momentum and centripetal force. The original poster presents a scenario with specific vector changes and seeks to determine the angular velocity of the particle.
  • Participants discuss the relationship between momentum and force vectors during the particle's rotation, noting the geometric properties of the vectors involved. There is an exploration of the similarity of triangles formed by these vectors and their implications for angular velocity.
Some participants have provided insights into the geometric relationships between the vectors, suggesting that the similarity of triangles can lead to conclusions about angular velocity. However, there is no explicit consensus on the final answer, and the discussion remains open to further exploration.
There is a mention of reluctance to provide additional information, indicating that some participants may be adhering to homework guidelines that discourage complete solutions. The discussion also highlights the importance of understanding the underlying principles rather than just arriving at an answer.
abhijitlohiya
A particle in UCM goes from a point A to B. The change in it's momentum is 2j and change in the centripetal force is 8i .Where i and j are unit vectors along X and Y axis. What is the angular velocity of the particle ?
The answer is 4 rad/s.
The magnitude of the momentum and force vectors do not change as the vectors rotate. The first diagram shows the two momentum vectors and their change as the particle rotated through an angle [tex]\phi[/tex] (I chose clockwise rotation. Mirror the vectors in the y-axis for anticlockwise rotation). The vectors form an isosceles triangle. The second diagram shows the two momentum vectors of the particle as it rotated from point A to point B.
Note that the force vectors form a similar triangle with the same angle [tex]\phi[/tex] between them. This is because the vectors are rotating together. From here on it is only two little more steps to the answer, so I am reluctant to provide any more information - the answer should be quite obvious from my two posts.
Thought I should post the answer for comlpeteness sake.
The two triangles formed by the momentum and force vectors are similar since all three angles are the same. This means that the ratio of their sides (the magnitude of the vectors) - are equal. Therefore:
[tex]\frac{mv^2}{8r} = \frac{mv}{2}[/tex]
so that
[tex]\frac{v}{r} = 4[/tex]
which is the required angular velocity of the particle.
  • · Replies 30 ·
  • · Replies 71 ·
  • · Replies 17 ·
  • · Replies 45 ·
18K
