Tension (related to Fe) Question and Gauss Question
  • Thread starter Thread starter mudkip
    Gauss Tension
This discussion addresses two physics problems: calculating tension in a pendulum system and understanding Gauss's law for electric fields. For the tension problem, the user must resolve the tension force (T) into its x and y components, ensuring that the sum of forces equals zero, incorporating gravitational force (Fg) and electric force (Fe). In the Gauss question, the user seeks guidance on computing electric fields for concentric shells and spheres, utilizing the formula Integral(EdA) = q/e, where E is constant and the surface area of a sphere is 4πr².
  • Understanding of vector components in physics
  • Knowledge of electric forces and gravitational forces
  • Familiarity with Gauss's law and its applications
  • Basic calculus for integrating over surfaces
  • Study the resolution of forces in two-dimensional systems
  • Learn about electric field calculations using Gauss's law
  • Explore the concept of tension in pendulum systems
  • Review the derivation of electric fields for spherical charge distributions
Students of physics, particularly those studying mechanics and electromagnetism, as well as educators seeking to clarify concepts related to tension and electric fields.
mudkip
I have two questions
Regarding tension:
Two balls are suspended as a pendulum from a shared point. The balls are held at angle theta (due to electric force). I understand that I am supposed to add the forces of the tension, the electric force and the force due to gravity, and that they should total zero, but for some reason I'm having issues with solving for tension. Should I be finding x component and y component of T and find a resultant T to then add to Fg and Fe? Or should I add the x components of Fg and Fe and Ft and then the y components of the same and then find resultant force? I'm solving for T so I can find Fe, which I'll then use to find q. The mass of the balls are the same.
Regarding Gauss:
My textbook offers no insight into how to compute electrical fields for concentric shell and sphere, and I can't seem to find much through internet searches. Wondering if someone could help explain how to solve for such a thing.
For the tension... if you know the angle, you should also be able to calculate the vertical component (what's holding the balls up?). Then you can calculate the total tension.
If you don't know the angle, keep in mind that two forces are acting on the ball (that the tension is opposing): electric and gravitational. They should form a vector directly opposite the direction of the tension force
For Gauss:
Draw a sphere around your spherical charge. You know Integral(EdA)=q/e (e is epsilon). E is constant, and the surface area of a sphere is 4*pi*r^2
  • · Replies 18 ·
  • · Replies 16 ·
