Why Does D'Inverno Equate Lbarg in the Palatini Approach?
Ray D'Inverno's book, "Introducing Einstein's Relativity," discusses the Palatini approach to deriving vacuum field equations of General Relativity (GR) in Section 11.6. The author equates Lbarg with specific terms derived from the Lagrangian Lg and the function Q(a,a), which are assumed to be zero to ensure the Lagrangian is stationary. This assumption is crucial for obtaining valid field equations, as it aligns with the principle of least action. The discussion emphasizes the necessity of these assumptions for the correct application of the Palatini approach in GR.
  • Understanding of General Relativity principles
  • Familiarity with Lagrangian mechanics
  • Knowledge of the Palatini approach versus the Einstein-Hilbert approach
  • Proficiency in tensor calculus and metric tensor concepts
  • Study the implications of the Palatini approach in General Relativity
  • Explore the principle of least action in classical mechanics
  • Learn about the derivation of field equations in the Einstein-Hilbert approach
  • Investigate the role of metric tensor density in GR formulations
This discussion is beneficial for physicists, mathematicians, and students specializing in theoretical physics, particularly those focusing on General Relativity and advanced mechanics.
maddy
Section 11.6 of Ray D'Inverno's book Introducing Einstein's Relativity
This section shows Palatini's approach in using an equivalent Lagrangian to obtain the vacuum field equations of GR and the connection.
From equation 11.39, we already have Lg=g(ab,b)T(c,ac)-g(ab,c)T(c,ab)-Lbarg+Q(a,a).(sorry, I tried to look up the instructions teaching how to type in equations here but couldn't find it)
Lbarg is chosen in such a way that both it and Lg will give rise to the same field equations.
The g here is the metric tensor density.
Q(a)=g(bc)T(a,bc)-g(ab)T(c,bc) and Stokes integral around the boundary of delgamma for this will render it zero coz Q(a) vanishes on the boundary of delgamma.
My problem is WHY the author equates
Lbarg=g(ab,c)T(c,ab)-g(ab,b)T(c,ac) coz this seems use the assumptions that Lg=0 and Q(a,a)=0!
If these assumptions were made, then only I could proceed to
=g(ab,c)T(c,ab)-1/2(g(ab,c)T(d,ad)+g(ab,a)T(d,bd))
=g(ab,c)T(c,ab)-1/2(g(ab,c)T(d,ad)del(c,b)+g(ab,c)T(d,bd)del(c,a))
=>delLbarg/delg(ab,c)=T(c,ab)-1/2.del(c,b)T(d,ad)-1/2.del(c,a)T(d,bd)
which is equation 11.43 in the book.
I just can't figure out WHY Lg=0 and Q(a,a)=0!
Firstly, it is important to note that the equations in this section are derived using the Palatini approach, which differs from the more commonly known Einstein-Hilbert approach. In this approach, the connection is treated as an independent variable, rather than being determined by the metric tensor as in the Einstein-Hilbert approach.
To understand why Lg and Q(a,a) are assumed to be zero, we must look at the fundamental principle of least action, which states that the true equations of motion are those which minimize the action. In this case, the action is given by the integral of the Lagrangian over spacetime. In order to obtain the correct field equations, the Lagrangian must be chosen in such a way that it is stationary, i.e. its variation with respect to the metric and connection vanishes.
In equation 11.39, we see that Lg and Q(a,a) are the only terms that contain both the metric tensor and connection. In order for the Lagrangian to be stationary, these terms must be set to zero. This leads to the equation Lg=0 and Q(a,a)=0, which are then substituted into the expression for Lbarg in equation 11.43.
In summary, the assumptions of Lg=0 and Q(a,a)=0 are necessary in order to obtain the correct field equations using the Palatini approach. Without these assumptions, the Lagrangian would not be stationary and the equations of motion would not be valid. I hope this helps to clarify your understanding of this section.
  • · Replies 21 ·
  • · Replies 20 ·
