Generating Mechanical Excitations on Solid Masses (Earth)
  • Context: Graduate
  • Thread starter Thread starter Victordon
    excitations Mechanical
This discussion focuses on alternative methods for generating mechanical excitations in solid masses, specifically the Earth, beyond traditional techniques such as seismic activities, nuclear detonations, and dynamite usage. A proposed method involves modifying a pneumatic jackhammer by replacing its chisel end with a "thumper" plate and creating a custom control unit to adjust the frequency. The effectiveness of this approach hinges on ensuring that the resonant frequency of the ground material is within the operational range of the modified jackhammer. The conversation emphasizes the importance of understanding the required frequency range before proceeding with any modifications.
  • Understanding of mechanical excitation principles
  • Familiarity with pneumatic tools, specifically jackhammers
  • Knowledge of resonant frequency concepts in solid materials
  • Basic electronics for constructing custom control units
  • Research the principles of mechanical excitation and shock wave generation
  • Explore modifications for pneumatic jackhammers to control frequency
  • Study resonant frequency analysis techniques for geological materials
  • Investigate custom control unit design for variable frequency applications
Geophysicists, engineers involved in seismic research, and researchers exploring alternative methods for studying Earth formations will benefit from this discussion.
Victordon
Could someone please assist me with other ways to generate mechanical excitations on a solid mass(e.g earth) apart from seismic activities, nuclear detonation, use of dynamite and percusion( like use of hammer on rocks)?
The essence of this is to actually find out the resonance frequencies of Earth formations using these other means to try and achieve these frequencies.
Thanks
Curiously enough, the methods you've already described are such to induce very strong 'shock waves' through the material, which is an ideal investigative method.
One thought that comes to mind is modifying a pneumatic jackhammer. The modification would consist of replacing the chisel end with a "thumper" plate(already exists) and being able to control the frequency of the jackhammer(likely you would need to build some sort of custom made control unit) In any event, should the resonant frequency of the ground material be higher than the maximum frequency of the jackhammer it will not work.
So, I would study first on the frequency range you may need, then, throw someone a thousand dollars to construct a custom made variable frequency jackhammer.
lol. Thanks for this incite. looks like you could make do with more than a thousand dollars...
  • · Replies 20 ·
