Is it possible to harness energy from the earths magneic field?
  • Context: Undergrad
  • Thread starter Thread starter nuts2546
    Energy Field
The discussion revolves around the feasibility of harnessing energy from the Earth's magnetic field. Participants explore various theoretical and experimental approaches, including the use of coils, conductors, and the interaction of magnetic fields with other forces. The conversation spans concepts from physics and engineering, touching on practical applications and speculative ideas.
  • Experimental/applied
  • Some participants propose using a conductor moved through the Earth's weak magnetic field to generate electricity, although they express skepticism about its practicality.
  • One participant questions the mass of wire needed to generate a specific current in the Earth's magnetic field, indicating a technical inquiry into the mechanics involved.
  • Another participant suggests that external forces, such as wind or water, would be necessary to move the wire, highlighting the limitations of relying solely on the Earth's magnetic field.
  • Some participants mention historical experiments, such as NASA's attempt to use a long coil of wire in space to generate power, which ultimately failed.
  • There are ideas about using the magnetosphere for propulsion in spacecraft, suggesting a combination of solar power and the Earth's magnetic field.
  • Several participants discuss the concept of wireless electricity and its potential applications, including powering electric vehicles and homes through coils embedded in structures.
  • Speculative ideas include a large coil around the Earth or at the poles to harness solar wind or ambient energy, with varying degrees of feasibility discussed.
  • One participant shares thoughts on using a coil to create a magnetic field for energy collection, emphasizing the potential for minimal loss in energy transfer.
  • Another participant introduces the idea of a frictionless object in low Earth orbit generating energy through electromagnetic interactions, raising questions about its feasibility.
Participants express a range of views, with some agreeing on the limitations of the Earth's magnetic field for energy generation, while others propose various speculative methods without reaching a consensus on their feasibility or practicality.
Participants note the Earth's magnetic field's weakness and the necessity of external forces for energy generation. There are unresolved technical details regarding the implementation of proposed ideas, such as the specifics of coil design and energy transfer efficiency.
This discussion may be of interest to those exploring renewable energy technologies, electromagnetic theory, and innovative engineering solutions in the context of energy generation and propulsion systems.
nuts2546
The other day I pondered the possibility of harnessing energy from a magnetic field. I was thinkin about windfarms and wondered if a similar process could be created with a fan made of a suitable material in a vacuum. Using the Earths Magnetic field as the Energy Source. Any ideas people??.:confused:
Keeping in mind that the Earth's magnetic field is very weak, it is possible to create a generator simply by moving a conductor through it. It wouldn't likely be worth the effort and expense, though. I seem to recall that someone actually tried it a long time ago, but I'm not sure.
What mass of conducting wire would you need to pass through 1m (perpendicular to a uniform field of the same strength as the Earths, for simplicity) to generate 1A in the Earth's magnetic (B?) field?
We'd still need to move the wire, which would require some sort of external force, like wind or water. And we're not at a shortage of magnetic fields, either. Permenant magnets can be much stronger than the Earth's field anyways, and aren't really that expensive or rare.
Am I correct on that?
Correct. The Earth's magnetic field is far too weak to be useful in this respect.
You cannot get "free energy," period. Magnetic fields are not a "source" of energy, though by investing energy in pushing a wire through a magnetic field, one can produce electricity.
- Warren
NASA tried this with the space shuttle, extending a very long coil of wire out of the shuttle to let the vehicle's orbital motion through the magnetic field produce some of the juice needed to run instruments aboardship. But the tether broke as soon as ti reached its full length, and just kept going.
http://www.phy6.org/earthmag/wtether.htm
Up here in Alaska, there's quite a bit of research involved with the ionosphere and magnetosphere (the ionosphere is a layer of particles that I assume are carried by the magnetosphere on the inner layer of it, closest to earth).
While it can't be used for power, the military here has a high interest in its uses for communication and some conspiracy theorists claim it can be used to wipe out enemy communications (by sending some sort of explosion into the ionosphere).
Anyway, here's a page on http://en.wikipedia.org/wiki/HAARP" , the local military research group for the magnetosphere, there's even a controversy section for the conspiracy theorists!
(not that I don't suspect the militairy-industrial complex is always up to something.)
there was an experiment with an italian satelite on a tether, connected to the space shuttle. It generated a pretty high current, and a spark ended up breaking the tether, and the satelite was lost. The tether was like at least 10 milese long or something, it was visible from the ground.
there's also an idea to use the magnetosphere to boost spacecraft into higher orbits, or even to send them to the moon. Because if there is a charge on the wire, the wire will feel a torque, so the wire can be powered by solar panels on one side, and on the spacecraft would be on the other side. It's like using the sun's radiation and the Earth's magnetic field as propulsion.
Ask the Sun to send a flare in our direction:
http://science.nasa.gov/headlines/y2008/06may_carringtonflare.htm
Even more disconcerting, telegraph systems worldwide went haywire. Spark discharges shocked telegraph operators and set the telegraph paper on fire. Even when telegraphers disconnected the batteries powering the lines, aurora-induced electric currents in the wires still allowed messages to be transmitted.
aidil said:
Hi, just wanted to share... this here is a demo of wireless electricity. Gave me an idea... that if we could tune into our Earth's electromagnetic frequency, we might be able to use it to power up our tools. http://www.ted.com/talks/lang/eng/eric_giler_demos_wireless_electricity.html
I love it when ideas merge.
As a side note, this video was also available next to your posted video. http://www.ted.com/talks/shai_agassi_on_electric_cars.html
The idea of wireless power - with a "working" range of 1 meter would be ideal for EV's. The highway system in the US is ideal for wind, solar and (yes I'll go there again) static collection/conversion. We can easily deploy power to the highway system - maybe even enhance the overall power grid in the process. The real challenge is to make batteries light(er) weight.
Wireless recharging coupled with autos carrying multiple (lighter weight) batteries (2 to 5) could solve the problem of range. By employing multiple on-board batteries, the vehicle could run on 1 battery and simultaneously recharge the others during travel - and switch electronically as needed.
Why not put a coil around the outside of a house.
The magnetic field generated by electricity traveling through that coil will be the same at any point inside that coil. This magnetic field can then be used to power anything you want.
And you wouldn't have to use a big external coil. Just put a lot of turns on the internal coil to give you a higher voltage.
Doing this durring the construction phase of the house would be easy. Tie it directly into the mains feed to the house.
60 Hz on the exterior coil. Minimal loss unless there is a load on the internal coil. In which case the load would be what is used.
You wouldn't be able to travel too far outside of the plane of the coil, but if you put one coil on each floor, you should be fine.
I live in an area where the most intelligent thing to come out of most people mouths is 'Pass me that there katchup'... that's right. KATCHUP not ketchup...that always bugs me for some reason... anyway. I was ecstatic when I found this forum. I had an idea a while ago about possibly combining the speed of an object made of a frictionless( or at least very friction resistant) material, moving at high velocity through our atmosphere while maintaining a VERY Low Earth Orbit and the properties of electro-magnetism and atmospheric static to generate enough energy to maintain the orbit and still have some left over. Possibly even some kind of conducting coil circling around the entire planet that would simply absorb and store the ambient energy in our atmosphere. If we went with the coil idea, the force of the rotation would hopefully help with the energy cost of keeping it up there and allow more energy collection. I haven't had much in the way of education in this field yet so I thought I would ask here. Is this feasible?
I have pondered this many times. I came up with two ideas. Might they work?
The first, a coil buried around the northern hemisphere magnetically levitated and spun so that the solar wind travels through it.
The second, a coil around the entire Earth with a massive lobe. The coil should be lined up with the moons orbit so that the lobe would be pulled by the moons gravity. I guess this would slow the moons orbit and eventually crash it into the earth.
Care to explain this with a little more detail?
The idea is a coil that is buried and encircles one of the poles at a diameter of say 500 miles. The coil could be levitated of floated in fluid or like a maglev train and either spun or moved vertically by changing buoyancy or alternating magnetic attraction/repulsion. Or if tuned the coil could be vibrated or waved with sound at a resonate frequency. Probably the south pole is better because of the existing land mass.
The logistics might prove to be a challenge.
How much energy is stored in the magnetic field of the earth?
As the magnetic field itself is always changing, would it be possible to harness that energy with a stationary coil?
How big would the coil have to be to produce a useable energy?
But only very very slowly at any particular location.
ah, but take into consideration, all these theories deal with the Earth's magnetic field in either air or a vacuum, but what i would like to know is what effect does salt water have on the Earth's magnetic field as it passes through it? I know salt water is an electrolyte, so wouldn't that magnify the field? also if the magnetic field gets stronger the closer you get to the core, wouldn't the ideal location for a collector coil be in a mine or at the bottom of an ocean trench, e.g. the Marianas Trench?
johnnycactus said:
......The first, a coil buried around the northern hemisphere magnetically levitated and spun so that the solar wind travels through it...
The solar wind doesn't get to the Earth's surface let alone to anything buried below the surface
Dave
why would you think an electrolyte would increase the strength of a magnetic field
Dave
so true.
The only time there is a rapid ( and relatively short term) change is during times of "sudden impulses" caused by solar flares and coronal mass ejections CME's
These suddent impulses may last minutes to a few hours at the most
Dave
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 42 ·
  • · Replies 16 ·
13K
