Prove by Mathematical Induction: (13^n)-(6^n) Divisible by 7
The discussion revolves around proving by mathematical induction that the expression (13^n) - (6^n) is divisible by 7. Participants explore various approaches to establish the inductive step after confirming the base case.
  • Homework-related
  • One participant seeks guidance on how to proceed with the proof after establishing the base case.
  • Another participant suggests factoring (13^(k+1)) - (6^(k+1)) as a potential approach.
  • There is uncertainty about how to express (13^(k+1)) - (6^(k+1)) in terms of (13^k) - (6^k).
  • A participant provides a factorization: 13^(k+1) - 6^(k+1) = 13 * (13^k - 6^k) + 7 * 6^k.
  • Questions arise about the steps leading to the factorization and how to demonstrate divisibility by 7.
  • Another participant hints at a simpler solution involving a standard factorization for a^n - b^n.
Participants do not reach a consensus on the best method to prove the statement, and multiple approaches are discussed without resolution.
Some participants express uncertainty about the steps involved in the factorization and the implications for proving divisibility, indicating potential gaps in understanding the mathematical principles at play.
supasupa
Hey there evryone
I need some help with this problem as I don't know which direction to go with it.
Prove by mathematical induction that (13^n)-(6^n) is divisible by 7.
The Base Step is obviously ok...
Then assume (13^K)-(6^K) is true
Then have to prove (13^(k+1))-(6^(k+1)) is true... how do i do this
thank heaps...
Can you factor (13^(k+1))-(6^(k+1)) ?
yeah that's what i have been trying to do but i don't know how to get
(13^(k+1) - 6^(k+1))
as a multiple of (13^k - 6^k).
I don't know if this is the correct direction to take
[tex]13^{k+1}-6^{k+1}=13 \cdot (13^k-6^k)+7 \cdot 6^k[/tex]
how do you do that?
like what is the step u take to get there
i get
13.13^K - 6.6^K
then what do i do??
Instead of trying that... can you find a way to just show (13^(k+1) - 6^(k+1)) is divisible by seven? What looks like it equal seven in that equation?
supasupa said:
i get
13.13^K - 6.6^K
then what do i do??
=13.13^K-(13-7).6^K=13(13^K-6^K)+7.6^K
thank you very much...that makes a heap more sense now
:smile:
In all this, you've missed out the slightly easier solution Shredder was trying to point you to. There is a standard factorization for a^n - b^n. You use a specific case of this factorization when you write the sum of a geometric series : [itex]1+b+b^2+...+b^{n-1} = (1-b^n)/(1-b)[/itex]
  • · Replies 19 ·
