Why Can't the Motorcycle's Contact Point with the Wall Serve as a Pivot?
  • Context: Undergrad
  • Thread starter Thread starter bobbytkc
    Concept Torque
The discussion centers on the inability to consider the point of contact between a motorcycle and a wall as a pivot point due to the non-inertial nature of that point. Calculations show that using the contact point leads to nonsensical results when analyzing rotational motion. The principle of moments applies to static equilibrium, and while any point can theoretically be used to calculate torques, it must be within an inertial reference frame for accurate results. Thus, the motorcycle's contact point is not suitable for torque calculations.
  • Understanding of torque and rotational motion
  • Familiarity with the concept of center of mass
  • Knowledge of inertial and non-inertial reference frames
  • Basic principles of static equilibrium and the principle of moments
  • Study the effects of non-inertial reference frames on torque calculations
  • Learn about the dynamics of motorcycle lean angles during turns
  • Explore the application of the principle of moments in dynamic systems
  • Investigate the differences between static and dynamic equilibrium in physics
Physics students, mechanical engineers, and anyone interested in the dynamics of rotational motion and torque analysis in non-inertial frames.
bobbytkc
look here: http://www.mut.ac.th/~physics/PhysicsMagic/wall.htm"
scrolling to the motorcycle section, my question is, why is it that you cannot consider the point of contact of the motorcycle with the wall as a pivoting point? I have done some calculations, and this leads to a physically nonsensical answer.
I recognize that any line of force not acting through an object's centre of mass would produce a torque about an axis through the centre of mass,and that would indeed lead to a coherent answer, but my problem is, why can the point of contact NOT be considered a pivot? The motorcycle would rotate about that point after all.
Another point to clarify, the principle of moment states:
For rotational equilibrium, the sum of the clockwise moments about any point must be equal to the sum of the anti-clockwise moments about the same point.
Does 'any point' refers literally to any point within the frame of reference, of simply any point that can act as a pivot only?
Thanx.
To analyze the rotational motion of an object, calculate torques about its center of mass. If you use any other point as your pivot, be sure you are using one fixed in an inertial reference frame. The point of contact of the tire with the ground is accelerating, so it is not an inertial reference frame. (This same issue comes up in analyzing the lean angle of a bicycle or motorcycle turning a corner. If you use the center of mass, it's easy; if you use torques about the contact point with the ground you cannot simply apply Newton's laws without modification.)
As far as the "principle of moments" that you quoted, realize that that is usually applied to systems in static equilibrium. Any point can be used to calculate torques, since the system is viewed from an inertial frame.
  • · Replies 23 ·
