The role of gravity in terms of work done by an angled force on an incline
The discussion revolves around understanding the role of gravity in the context of work done by an applied force on an inclined ramp. The original poster expresses confusion about how gravity interacts with the applied force, particularly when the applied force is at an angle to the ramp.
  • Participants explore the components of gravitational force and their effects on the applied force. There is discussion about whether gravity does work and how it influences motion up the ramp. Some participants question the assumptions about the direction and components of forces involved.
Participants are actively engaging with the concepts, providing clarifications and diagrams to illustrate their points. There is a recognition of the complexity of the problem, with some guidance offered regarding the components of forces and their roles in the context of the incline.
The problem is part of a culminating activity in a grade 12 geometry and discrete math course, which may impose specific constraints on the approach to the problem. The discussion includes considerations of how to analyze forces in a non-standard coordinate system aligned with the ramp.
Cali
Problem's exact wording: When we looked at the work done by a force F, up a ramp, we were confused about the role of gravity that acts in the down direction. Investigate what work , if any gravity does and how this influences the applied force up the ramp acting on a mass.
Note on question: The applied force is at an angle to the ramp, and this was asked as part of a culminating activity in a gr.12 geometry and discrete math course.
My thoughts while looking at my pretty diagram: There's the normal acting perpendicular to the surface, gravity acting downwards, and an applied force acting at angle to the the ramp. So, gravity doesn't really do any work, since it's acting more like friction, the object it is acting on needs a greater applied force to cause motion. Gravity itself is not causing any displacement, and therefore no work. The gravity that acts in the down direction should be broken into its components. The horizontal component is acting in the direction of the ramp's incline,adding to the applied force? While the angled component has the same angle as the ramp, and acts opposite to the applied force, just like friction? except for the angle? Is what I'm thinking right? Help? Please?
When the gravity force is broken into the appropriate components,
i) one is acting along the horizontal axis along the ramp and it is added algebraically to the horizontal component of the applied force along the ramp.
ii) the second gravity force component is acting along the vertical axis of the ramp (perpendicular to the surface of the ramp), parallel to the normal force.
Keep in mind that the work done of gravity force does not depend on the angle of the inclination of the ramp. It only depends on the vertical height. As there is a change in height of the mass as the mass moves upward the ramp, there is work done by the gravity force, which is a negative work with respect to a conventional reference frame, if the direction of the applied force is assumed to be positive.
Just a clarification here. No component of the weight acts horizontally; one component however, does act parallel to the incline (down the slope). The below diagram should clarify further;
http://upload.wikimedia.org/wikipedia/en/e/e7/Free_body.gif
Here we can see that the force of gravity can be divided into two components [itex]mg\sin\theta[/itex], which acts perpendicular to the incline and [itex]mg\cos\theta[/itex] which acts parallel to the inclined plane. Note however, that there are no components of weight acting in the horizontal plane.
Thank you both! I would've never thought to consider the ramp the axis.
Yes, I wasn't referring to the horizontal with respect to the level ground, I meant horizontal axis along the ramp, that is the inclined coordinate system or plane. Please read carefully, Hootenanny.
EDIT: Here is a diagram depicting my point:
  • · Replies 28 ·
  • · Replies 56 ·
