Initial velocity required depend on the mass of projectile
The initial velocity required for a projectile does not depend on its mass when considering ballistic trajectories. Ballistic trajectories are determined by the momentum of the projectile and the constant acceleration due to gravity, which affects all objects equally regardless of mass. The time taken for any object to fall to the ground is the same, making mass irrelevant in this context. While heavier objects may experience a minuscule difference in fall rate due to their gravitational pull on the Earth, this is negligible and does not affect the fundamental principles of projectile motion.
  • Understanding of basic physics concepts, particularly Newton's laws of motion.
  • Familiarity with the principles of projectile motion.
  • Knowledge of gravitational acceleration and its effects on objects.
  • Basic understanding of air resistance and its negligible impact in ideal conditions.
  • Research the principles of projectile motion in detail.
  • Learn about the effects of air resistance on different types of projectiles.
  • Study Newton's laws of motion and their applications in real-world scenarios.
  • Explore advanced topics in orbital mechanics and their relation to ballistic trajectories.
Students of physics, educators teaching projectile motion, and anyone interested in understanding the dynamics of motion in gravitational fields.
techno
Does the Initial velocity required depend on the mass of projectile to impart a projectile of perticilar angle and perticular height?
No, balistic trajectories do not depend on mass. A balistic trajectory is the course a projactile takes as its momentum is balanced against gravity, and gravity accelerates all freefalling objects at pretty much the same rate. So the forward speed of a projectile determines how far it will travel in the amount of time it takes to fall to the ground, the that amount of time is the same for heavy or light things. In fact, a balistic trjectory is a segmant of an orbit.
All this is neglecting any differences in wind resistance, of course.
Now, if one wanted to get really picky, I suppose it can be said that more massive objects do fall a tiny bit faster than lighter objects because, all though the Earth's gravitationl pull on both objects is the same, the heavier object has a stronger pull on the Earth. But that would be silly.
It would be not only both silly and picky, it would be incorrect. Neglecting air resistance, the rate at which an object and the Earth accelerate toward each other is independent of the mass of the object.
  • · Replies 60 ·
  • · Replies 16 ·
  • · Replies 25 ·
