Calculating Spring Constant of a Hanging Spring
The discussion revolves around calculating the spring constant of a hanging spring when a mass is attached, as well as determining the acceleration of the mass when it is pulled from its rest position. The subject area includes mechanics and spring dynamics.
  • Participants discuss the application of Hooke's Law and Newton's second law to find the spring constant and the acceleration of the mass. There are questions about the correctness of the formulas used and the interpretation of the variables involved.
Some participants have offered guidance on the correct application of formulas, while others have confirmed the reasoning behind the calculations. Multiple interpretations of the problem setup are being explored, particularly regarding the spring's stretching distance and the forces at play.
There are indications of confusion regarding the signs in the equations and the specific distances used in calculations. Participants are encouraged to clarify their reasoning and show their work for better understanding.
teng125
A spring with length l = 8 cm hangs in
vertical direction somewhere close the Earth's surface. When a mass of m = 10 kg is attached
to the spring its rest-position is at y0 = 11 cm. (a) Determine the spring constant k.
i try to use F=-kx = mg where x=11cm - 8cm
therefore,i would like to know whether my steps are correct or i used the wrong formula
somebody pls help
part b) The
mass is pulled out of its rest-position by a distance Δy = 5 cm. What is the acceleration acting
on the mass in the moment of its release?
i got the answer of a=16.35m/s^2
am i right??
somebody pls help
You're in the right direction :) Remember that at the spring its rest position [tex]F_{gr.} = F_{spring} = C \cdot u[/tex] where C = spring constant.
So you need to solve: [tex]m \cdot g = C \cdot u[/tex] with u = distance of strecthing of the spring (3 cm)
foir b i would say that you use the second law of Newton: [tex]F_{res} = m \cdot a[/tex]
You are correct. (Except for that minus sign. Set the magnitude of the spring force equal to the magnitude of the weight.)
teng125 said:
part b) ...
am i right??
Looks OK to me. (But next time don't just give your answer; show how you got your answer. :wink: )
agrees with Doc Al :)
  • · Replies 27 ·
