Total Work of 2 Carnot Engines | 890K & 670K
  • Thread starter Thread starter KingTutATL
    Engine Heat
The discussion focuses on the operation of two Carnot engines with specific temperature reservoirs: the first engine operates between 890K and 670K, while the second engine operates between 670K and 420K. The heat input for the first engine is 4800J. The efficiency of each engine is calculated using the formula η = 1 - (T_C/T_H), leading to the determination of total work output from both engines. The process involves calculating the work output of the first engine and using its rejected heat as input for the second engine.
  • Carnot engine principles
  • Thermodynamic efficiency calculations
  • Heat transfer concepts
  • Understanding of temperature scales in Kelvin
  • Calculate the efficiency of the first Carnot engine using η = 1 - (T_C/T_H)
  • Determine the work output of the first engine based on the heat input of 4800J
  • Analyze the rejected heat from the first engine to find the heat input for the second engine
  • Calculate the work output of the second Carnot engine using its respective temperature reservoirs
Students and professionals in thermodynamics, mechanical engineers, and anyone interested in understanding the efficiency and work output of Carnot engines.
KingTutATL
The hot reservoir for a Carnot engine has a temperature of 890K, while the cold reservoir has a temperature of 670K. The heat input for this engine is 4800J. The 670K reservoir also serves as the hot reservoir for a second Carnot engine. This second engine uses the rejected heat of the first engine as input and extracts additional work from it. The rejected heat of the first engine as input and extrats additional work from it. The rejected heat from the second engine goes into a reservoir that has a temperature of 420K. Find the total work delivered by the 2 engines?
I'm lost
I'm lost
What is the efficiency of a Carnot engine? Remember:
[tex]\eta = \frac{W_{output}}{Q_H}[/tex]
AM
Also useful will be the fact that the efficiency is also
[tex]\eta = 1 - \frac{T_C}{T_H}[/tex]
So, calculate the work output from the first engine, from that calculate the heat transferred to the first cold resevior... Wash, rinse, repeat to find the work output of the second engine, and you're pretty much in the clear.
