How to prove e^ix=cos x + i sin x
  • Context: Undergrad
  • Thread starter Thread starter HeilPhysicsPhysics
    Sin
The discussion centers around the proof of the equation e^ix = cos x + i sin x, exploring various methods of derivation and the historical context of the formula. Participants delve into mathematical reasoning, including Taylor series, differential equations, and historical perspectives.
  • Historical
  • One method proposed involves using the Taylor series for e^x and substituting ix, while considering the powers of i.
  • Another participant suggests that the proof relies on definitions of cosine and sine in terms of exponential functions, making the derivation straightforward.
  • A detailed approach using differential equations is presented, where e^{ix} is expressed as a combination of real and imaginary parts, leading to unique solutions for f(x) and g(x) that correspond to cosine and sine.
  • A participant introduces a differential equation derived from the expression z = cosθ + i sinθ, concluding that its solution is z = e^{iθ}.
  • Historical context is provided, mentioning Euler's work related to the harmonic oscillator and how it connects to the derivation of the formula.
Participants present multiple methods and perspectives for proving the equation, indicating that there is no single agreed-upon approach. The discussion remains open with various competing views and techniques being explored.
Some methods depend on specific definitions of trigonometric functions, and the discussion includes various mathematical techniques that may not be universally accepted or applicable in all contexts.
HeilPhysicsPhysics
One way is to start with the taylor series for ex and then change x to ix and remembering that
i2 = -1, i3 = -i, and i4 = 1 you can rearrange the series and show that this is equal to the other side of that equation.
The proof depends on your definitions (for example, if you define [itex]\cos{x}[/itex] as [itex](e^{ix}+e^{-ix})/2[/itex] and [itex]\sin{x}[/itex] as [itex](e^{ix} - e^{-ix})/(2i)[/itex] then it's pretty easy!).
It's also clear if you start from the Taylor series of the three functions about the origin as d_leet suggested.
You can also start from the differential equation for e^x,
[tex]y^\prime = y, y(0)=1.[/tex]
Write
[itex]e^{ix} = f(x) + ig(x),[/itex]
(where f, g are real-valued)
so that [itex]f(0) = 1[/itex] and [itex]g(0) = 0[/itex]
then you must have (by the chain rule)
[tex]ie^{ix} = f^\prime(x) + ig^\prime(x),[/tex]
or, rearranging,
[tex]e^{ix} = \frac{1}{i}f^\prime(x) + g^\prime(x) = g^\prime(x) - if^\prime(x).[/tex]
Since [itex]e^0 = 1[/itex] that means [itex]g^\prime(0) = 1[/itex] and [itex]f^\prime(0) = 0[/itex]. Now differentiate again and you get
[tex]ie^{ix} = g^{\prime \prime}(x) - if^{\prime \prime}(x)[/tex]
or
[tex]e^{ix} = -f^{\prime \prime}(x) - ig^{\prime \prime}(x).[/tex]
Comparing the real and imaginary parts with our original [itex]e^{ix} = f(x) + ig(x)[/itex] you get two differential equations with initial conditions:
[tex]f^{\prime \prime}(x) = -f(x), f^{\prime}(0) = 0, f(0) = 1[/tex]
and
[tex]g^{\prime \prime} (x) = -g(x), g^{\prime}(0) = 1, g(0) = 0.[/tex]
It's easy to check that f(x) = cos(x) and g(x)= sin(x) satisfy these DEs, and by a theorem in the theory of DEs the solutions are unique.
Let [tex]z = \rm{cos}\theta + i \cdot \rm{sin}\theta[/tex]
Then derive z:
[tex]\frac{\rm{d}z}{\rm{d}\theta} = - \rm{sin}\theta + i \cdot \rm{cos}\theta = -1 (\rm{sin}\theta - i \cdot \rm{cos}\theta) = i^2 (\rm{sin}\theta - i \cdot\rm{cos}\theta ) = i (i \cdot \rm{sin}\theta - i^2 \cdot \rm{cos}\theta) = i(\rm{cos}\theta + i \cdot \rm{sin}\theta) = i \cdot z[/tex]
This is a differential equation:
[tex]\frac{\rm{d}z}{\rm{d}\theta} = i z[/tex]
whose solution is
[tex]z = e^{i \theta}[/tex]
Thus, [tex]\rm{cos}\theta + i \rm{sin}\theta = e^{i \theta}[/tex]
Umm.. in fact i think that the "historical" development fo the formula came with euler when studying the "Harmonic (classical) oscilator"..
[tex]y'' + \omega ^2 y =0[/tex] trying y=exp(ax) then you get..
[tex]a^2 +\omega ^2 =0[/tex] so [tex]+ \sqrt (-1) \omega =a[/tex] (and the same
with a minus sign)
-On the other hand the long-known solution for the Harmonic movement was [tex]y= Asin (\omega t) +B Cos(\omega t)[/tex] then if you set the initial condition [tex]y(0)=0[/tex] you get the identity for sin. and using the well-known formula [tex]cos^2 (x) + sen^2 (x) =1[/tex] oh..if today math were so easier...i would have became famous years ago... :o :o
