What is the Joule-Thomson Coefficient?
  • Thread starter Thread starter mbeychok
    Coefficient
The Joule-Thomson coefficient (µ) quantifies the temperature change of a real gas during isenthalpic expansion, defined mathematically as µ = (dT/dP) at constant enthalpy. This coefficient varies with the specific gas and its initial temperature and pressure, with an inversion point where µ equals zero. Below this inversion temperature, µ is positive, resulting in cooling, while above it, µ is negative, leading to heating. Notably, helium and hydrogen exhibit low inversion temperatures, causing them to warm upon expansion at atmospheric pressure.
  • Understanding of thermodynamics, specifically isenthalpic and isentropic processes
  • Familiarity with the concept of inversion temperature in real gases
  • Knowledge of the properties of gases, including helium and hydrogen
  • Access to "Perry's Chemical Engineers' Handbook" or similar reference materials
  • Research the Joule-Thomson effect in various gases using "Perry's Chemical Engineers' Handbook"
  • Explore the differences between isenthalpic and isentropic gas expansions
  • Study the implications of the Joule-Thomson coefficient on refrigeration cycles
  • Investigate the behavior of gases at their inversion temperatures in practical applications
Students and professionals in chemical engineering, thermodynamics, and physical chemistry, particularly those involved in gas processing and refrigeration technologies.
mbeychok
When a real gas, as differentiated from an ideal gas, expands at constant enthalpy (i.e., no heat is transferred to or from the gas, and no external work is extracted), the gas will be either cooled or heated by the expansion. That change in gas temperature with the change in pressure is called the Joule-Thomson coefficient and is denoted by µ, defined as:
The value of u depends on the specific gas, as well as the temperature and pressure of the gas before expansion. For all real gases, µ will equal zero at some point called the "inversion point". If the gas temperature is below its inversion point temperature, µ is positive ... and if the gas temperature is above its inversion point temperature, µ is negative. Also, dP is always negative when a gas expands. Thus:
If the gas temperature is below its inversion temperature:
-- µ is positive and dP is always negative​
-- hence, the gas cools since dT must be negative​
If the gas temperature is above its inversion temperature:
-- µ is negative and dP is always negative​
-- hence, the gas heats since dT must be positive​
"Perry's Chemical Engineers' Handbook" provides tabulations of µ versus temperature and pressure for a number of gases, as do many other reference books. For most gases at atmospheric pressure, the inversion temperature is fairly high (above room temperature), and so most gases at those temperature and pressure conditions are cooled by isenthalpic expansion.
Helium and hydrogen are two gases whose Joule-Thomson inversion temperatures at atmospheric pressure are very low (e.g., about −222 °C for helium). Thus, helium and hydrogen will warm when expanded at constant enthalpy at atmospheric pressure and typical room temperatures.
It should be noted that µ is always equal to zero for ideal gases (i.e., they will neither heat nor cool upon being expanded at constant enthalpy).
By contrast, when external work is extracted during the expansion of a gas (as when a high-pressure gas is expanded through a turboexpander), the expansion is isentropic (i.e., occurs at constant entropy) rather than isenthalpic as in a Joule-Thomson expansion. For an isentropic gas expansion, the gas temperature always cools and the temperature drop is more than would be achieved by an isenthalpic Joule-Thomson expansion.
Milt Beychok
Thanks for sharing. Very informative.
This was a necro post from 2006. It didn't ask any question, so it got no replies. But it does have 39K views from people who found it via Internet searches. It must be a really hot topic.
In 2019, we have PF Insights for articles in addition to threads for questions. Alas, I can't contact the OP. His email bounces. But I am bumping it in the Materials forum just to bring it to your attention.
@anorlunda There is a section on Joule-Thomson in practically every thermo book that covers essentially this same material.
  • · Replies 28 ·
  • · Replies 20 ·
  • · Replies 17 ·
14K
