Phase determination in 3 phase circuits
The discussion focuses on determining the phase in which current flows in a 3-phase induction motor circuit. The user has successfully implemented a true RMS measurement algorithm using the sum of squares method for calculating RMS values of voltages and single-phase current. To calculate power accurately, the user seeks an algorithm to identify the specific phase of current flow, emphasizing that the load is inductive and the current lags the voltage. The solution involves measuring the phase angle between voltage and current to ascertain the correct phase.
  • Understanding of 3-phase induction motors
  • Knowledge of true RMS measurement techniques
  • Familiarity with phase angle concepts in electrical circuits
  • Experience with power calculation in AC circuits
  • Research algorithms for phase angle measurement in 3-phase systems
  • Explore methods for calculating power in inductive loads
  • Learn about true RMS measurement tools and techniques
  • Investigate the impact of phase differences on power factor in AC circuits
Electrical engineers, technicians working with 3-phase induction motors, and anyone involved in power measurement and analysis in AC circuits.
vinay.hn
Hi!
I'm working on a 3 phase induction motor. I need to measure the RMS values of three phase voltages, and single phase current which further feed power to the induction motor. I've implemented the true rms measurement (sum of squares method) algorithm for RMS value calculations and readings are fine. For calculation of power I need to multiply the current with the corresponding voltage. But I don't know in which phase the current is being drawn.
So, in case of 3 phase circuits, is there any algorithm to determine the phase in which the current flows? One point to keep in mind is that the load will always be inductive and the current always lags the voltage in that phase.
Please help.
Thanks
You need the phase angle between voltage and current.
It's not enough to know that it lags.
Pick any winding to measure both.
  • · Replies 77 ·
9K
  • · Replies 31 ·
  • · Replies 17 ·
  • · Replies 20 ·
