Which Equation Correctly Represents the Reaction Between HCHO2 and K2CO3?
  • Thread starter Thread starter lkh1986
The correct molecular equation for the reaction between HCHO2 (formic acid) and K2CO3 (potassium carbonate) is 2HCHO3 + K2CO3 --> H2O + CO2 + 2KCHO2. This indicates that H2CO3 (carbonic acid) does not exist in solution and dissociates into H2O and CO2. For the ionic equation, the second option, 2HCHO2 + 2K+ + CO32- --> H2O + CO2 + 2K+ + 2CHO2-, is preferred as it accurately reflects the neutralization reaction while acknowledging the presence of K+ ions that cancel out on both sides.
  • Understanding of acid-base reactions, particularly weak acids.
  • Knowledge of molecular and ionic equations in chemistry.
  • Familiarity with the dissociation of acids in aqueous solutions.
  • Basic grasp of chemical reaction balancing techniques.
  • Study the dissociation of weak acids in solution, focusing on HCHO2.
  • Learn about the principles of balancing molecular and ionic equations.
  • Explore the properties and reactions of carbonic acid (H2CO3) in aqueous solutions.
  • Investigate the role of potassium ions (K+) in neutralization reactions.
Chemistry students, educators, and professionals involved in chemical reaction analysis, particularly those focusing on acid-base chemistry and ionic equations.
lkh1986
The molecular equation for the reaction between HCHO2 and K2CO3 is
2HCHO3 +K2CO3 --> H2CO3 + 2KCHO2.
H2CO3 will undergo further reaction to become H2O and CO2, so maybe the molelar equation can be written as 2HCHO3 +K2CO3 --> H2O + CO2 + 2KCHO2. Which of the molecular equation is the correct one?
Then, for ionic equation, which one of the following is the correct one?
2HCHO2 + 2K+ + CO32- --> H2CO3 + 2K+ + 2CHO2-
or
or
2H+ + 2CHO2- + 2K+ + CO32- --> H2CO3 + 2K+ + 2CHO2-
or
2H+ + 2CHO2- + 2K+ + CO32- --> H2O + CO2 + 2K+ + 2CHO2-
Do we need to separate the acid? But then again it is a weak acid.
However, since this reaction is a neutralization reaction between an acid and a base, it would be weird if we don't separate the acid into ions. Technically, small percene of the acid do ionize.
The second is correct, because H2CO3 doesn't exist in a solution and always dissociates in H2O and CO2.
or
or
or
none are correct, since you have equal amount K+ on both sides of the arrow so they cancel each other out. But apart from that i would go for the second one.
assume the reaction takes place completely all HCOOH will form HCOO-
  • · Replies 16 ·
