Thread Closed
ductile or brittle
Share Thread Thread Tools
Aug16-06, 07:31 AM   #1
ductile or brittle
i force-elongation diagram, how can we know whether the material is ductile or brittle??any formula to calculate it??
pls help
thanx
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Aug16-06, 07:39 AM   #2
They can be identify quite easily as the following:
If there is a very long section after yielding point, which we call the plastic deformation section, existing in the curve then it is ductile.
If the curve is basically just a short section of straigth line obeying Hooke's law followed by a small, short curve indicating the breaking point or UTS, then it is brittle.
Aug16-06, 09:49 AM   #3
Recognitions:
Gold Membership Gold Member
Just keep in mind that the actual micromechanism of fracture is not always that straightforward to identify from a force-displacement curve, in a case where several coexist (for example brittle failure can result after quite extensive plasticity). Typical formula would be those typically related to stress-strain curves or then fracture mechanical ones (usually the former, but don't know the "level" of your problem).
Thread Closed
Thread Tools
Similar Threads for: ductile or brittle
Thread Forum Replies
Heat Treating of Ductile Irons Materials & Chemical Engineering 3
Question about a brittle material with a flaw Engineering, Comp Sci, & Technology Homework 1
Is perfect crystal brittle? Introductory Physics Homework 15
