linux kid
- 101
If magnetic fields aroung a coil of wire were turned on and off at a certain frequency, would it generate some form of energy?
The discussion revolves around the concept of generating energy through switching magnetic fields in a coil of wire. Participants explore the implications of turning magnetic fields on and off at certain frequencies, examining the resulting electrical waveforms and their characteristics.
Participants express differing views on the nature of the waveforms generated by switching magnetic fields, with some supporting the idea of square waves and others emphasizing sine waves. The discussion remains unresolved regarding the exact characteristics of the generated currents and the implications of rapid switching.
Participants reference mathematical concepts such as the dirac delta function and the derivative of the unit step function, indicating a reliance on specific definitions and assumptions that may not be universally understood. The discussion also highlights the practical limitations of achieving instantaneous switching in real-world scenarios.
We call these generators. Ok, that's a little sarcastic, but the principle of spinning windings past magnets has the effect you are talking about.linux kid said:If magnetic fields aroung a coil of wire were turned on and off at a certain frequency, would it generate some form of energy?
WhyIsItSo said:I suppose if you turned the magnetic fields on and off, you'd generate a square wave, while a generator creates a sine wave,
Which part are you talking about?ZapperZ said:Er.. you do?
The current generated in the coils would be proportional to the rate of flux across the coils' area, i.e. [itex]\frac{d\Phi}{dt}[/itex]. So if you have a sine wave, the time derivative of that would also be a sinusoidal wave with a phase shift (ignoring self induction).
WhyIsItSo said:Which part are you talking about?
In the hypothetical scenario where a magnetic field was either on or off, and oscillated between these states at a high enough frequency, would that not generate a square wave?
If referring to my comment about a generator, do they not create a sine wave? Is not a sine wave sinusoidal?
phun said:I think you'd get a train of delta functions (pulses) of electricity that way.
