How Do You Calculate the Solubility of AgBrO3 from Given Data?
The discussion revolves around calculating the solubility product constant (Ks) for silver bromate (AgBrO3) based on its solubility data. Participants explore the relationship between solubility and the solubility product, addressing both theoretical and practical aspects of the calculation.
  • Homework-related
  • One participant presents the solubility of AgBrO3 as 0.196 g/100 mL and seeks assistance in calculating the solubility product constant.
  • Another participant suggests that the initial poster may already have the answer but might be expecting different units (e.g., g/L, mol/L).
  • A participant clarifies that the goal is to find the solubility product constant, not just the solubility.
  • Several participants discuss the general form of the solubility constant and its relationship to the dissociation of the salt into ions.
  • One participant provides a detailed calculation, converting the mass of AgBrO3 to moles and deriving the concentrations of silver and bromate ions, ultimately leading to a formula for Ks.
  • Another participant expresses confusion about the process and seeks further clarification.
Participants generally agree on the method for calculating the solubility product constant, but there is some confusion regarding the initial steps and the interpretation of the solubility data. The discussion remains partially unresolved as not all participants fully understand the calculations presented.
Some participants reference the need for specific units and the molecular weight of silver bromate, indicating that assumptions about these factors are crucial for the calculations. There is also a reliance on the dissociation formula, which may not be universally agreed upon without further clarification.
This discussion may be useful for students or individuals interested in chemistry, particularly those studying solubility and equilibrium constants in the context of ionic compounds.
lo2
I have this salt [tex]AgBrO_{3}[/tex] which has got the solubility of [tex]\frac{0,196g}{100mL}[/tex]. From the following information I should be able to calculate Solubility for [tex]AgBrO_{3}[/tex].
I really cannot see how? So please help me.
It is really an Urgent matter so a quick replay would be most appreciated!
unless I am completely misreading it I think you already have your answer. Maybe you are expecting different units? [g/L, mol/L, etc]
No I want to find the solubility product constant...
well the solubilty constant is much like any other equilibrium constant.
A reaction of the form
AB{s} -> xA(+){aq} + yB(-){aq} where the x and y are balanced coefficients, and the species A(+) and B(-) are the charged ions ( not necessarily of charge 1)
Then the solubility constant ( call it K(s)) is
K(s) = ([A(+)]^x) * ([B(-)]^y)
where [A(+)] and [B(-)] are the concentrations of species A and B. Do you have the reaction formula for the dissociation of Silver Bromate?
I know that. That is not the problem.
My problem is how to find the Solubilty product constant, from that one and only piece of information I have got, which is that the solubility for [tex]AgBrO_{3}[/tex] is [tex]\frac{0,196g}{100mL}[/tex]. That is the problem!
remember, you can use the molecular weight of silver bromate (235.77 g/mol) to figure out the amount of moles/L of both the silver and bromate ions that were dissolved. From there these values can be plugged in as A(+) and B(-) with x and y both being 1.
I do not quite think that I understand.
ok
Silver Bromate dissocates into and silver ion and bromate ion as follows:
AgBrO(3) -> Ag(+) + BrO3(-).
By the formula for solubility constants the constant for this reaction would be
K(s) = [Ag(+)]*[BrO3(-)].
So all we need to get is the concentration (in moles/L) of these ions. You have the information of g/mL. Specifically 0.196 g/mL. To convert that to an equivalent moles/L first convert the amount of mass dissolved (0.196g) into moles.
0.196 g / 235.77 g/mol = 0.000831 moles.
Now this is in 100 mL or 0.1 L.
Therefore the amount of moles dissolved / liter is
0.000831 moles / 0.1 L = 0.00831 moles/L (commonly referred to as M)
From the above equation we know that for each mole of silver bromate dissolved there is exactly 1 mole of silver AND 1 mole of bromate. Therefore the concentration of silver ([Ag(+)]) is 0.00831 moles/L and likewise the concentration of bromate ions is the same.
Therefore the solubility constant is:
0.00831 * 0.00831 = Answer
a different, but similar, example can be seen here:
http://faculty.kutztown.edu/vitz/limsport/LabManual/KSPWeb/KSP.htm
Wow some explanation!
I owe you a favour just request and I will help you out if I can.
  • · Replies 48 ·
10K
