Find Length of Curve: y=x^2+2 from 0-3
  • Thread starter Thread starter tandoorichicken
    Curve Length
The discussion revolves around finding the length of the curve defined by the equation y = (1/3)(x^2 + 2)^(3/2) from x = 0 to x = 3. The subject area pertains to calculus, specifically the application of integral calculus to determine arc length.
  • Mathematical reasoning, Assumption checking
  • The original poster attempts to apply the arc length formula but questions their application of the derivative and the resulting integral. They seek clarification on whether their setup is correct and express uncertainty about the integral's complexity.
Participants are actively engaging with the problem, with one noting a mistake in the application of the chain rule for differentiation. Another participant points out a potential simplification of the integral, suggesting that the expression can be rewritten in a more manageable form. There is a collaborative atmosphere as participants help each other identify errors and clarify concepts.
There is an indication of confusion regarding the correct application of the arc length formula and the differentiation process, which may affect the integral setup. Participants are exploring various interpretations of the problem and the implications of their calculations.
tandoorichicken
Find the length of [tex]y = \frac{1}{3} (x^2 + 2)^{\frac{3}{2}}[/tex] from x=0 to x=3.
I used the formula [tex]s = \int_{a}^{b} \sqrt{1 + \frac{\,dy}{\,dx}} \,dx[/tex].
After plugging everything in, I got
[tex]s = \int_{0}^{3} (1 + \frac{1}{4} (x^2 + 2))}^\frac{1}{2} \,dx[/tex]
Now, this isn't an integral I've learned how to do, so
1) Did I do anything wrong, and
2) If yes, what?
I realized I forgot to use the chain rule when doing dy/dx. However when I do that, I get even a messier integral,
[tex]s = \int_{0}^{3} (1 + x^2(x^2 + 2))^\frac{1}{2} \,dx[/tex]
It should be
[tex]s = \int_{a}^{b} \sqrt{1 + (\frac{\,dy}{\,dx})^2} \,dx[/tex]
But that's not the pro u just wrote the wrong one and applied the right
u also have
[tex]1+x^2(x^2+2) = 1+x^4+2x^2=x^4+2x^2+1=(x^2+1)^2[/tex]
Is it enough
Woah yeah, thanks, overlooked a simple thing there.
  • · Replies 18 ·
  • · Replies 19 ·
