Magnitude of electric field - Problem check
The discussion focuses on calculating the magnitude of an electric field for a charged object using the principles of physics from the book "Cutnell & Johnson Physics." The user initially attempted to apply the equation E = k|q| / r^2 but was corrected to use F = qE instead, as the electric field is uniform and not produced by a point charge. The correct approach involves determining acceleration from the object's motion and then using F = ma to find the force before calculating the electric field.
  • Understanding of electric fields and forces (F = qE)
  • Knowledge of kinematics, specifically acceleration and motion equations
  • Familiarity with the concepts of charge (q) and mass (m)
  • Basic grasp of physics equations from "Cutnell & Johnson Physics"
  • Learn how to calculate acceleration from final velocity and time
  • Study the relationship between force, mass, and acceleration (Newton's Second Law)
  • Explore uniform electric fields and their properties
  • Review examples of electric field calculations in different charge distributions
Students studying physics, educators teaching electric fields, and anyone preparing for exams involving kinematics and electrostatics.
duki
Hey everyone. I've been getting tons of help on here and it's paying off. I really appreciate your efforts. Could someone check this problem for me and tell me if I have the right answer?
Book: Cutnell & Johnson Physics
pp. 571 #66
A small object, which has a charge q = 7.5uC and mass m = 9.0 x 10^-5kg, is placed in a constant electric field. Starting from rest, the object accelerates to a speed of 2.0 x 10^3m/s in a time of 0.96 s. Determine the magnitude of the electric field.
My Answer:
I found the equation for the magnitude of an electric field: E= k|q| / r^2
I wasn't sure how to find r but I noticed I had a and t so I did the following: r = (2.0 x 10^5) x (9.6)^2 / 2 = 1.8 x 10^8
I did that because, in order to find the time you do sqrt{2(distance)/(accel)} correct?
Then I did E = (8.99 x 10^9) x (7.5 x 10^-6) / (1.8 x 10^8)^2 = 2.08 x 10^-12
I figure if I messed up it's probably doing the reverse acceleration equation. Can someone check for me? Thanks! :smile:
pp. 571 #66
My Answer:
No, you cannot use this equation here. The E field is uniform which tells you that it is *not* produced by a point charge. It is produced by a large uniformly charged surface or some other charge distribution. The only thing you can use then is F=q E.
So you must use the information about the motion to find the acceleration, then use F=m a to find the force and then use F=qE to find the magnitude of the E field.
[/quot]e
I am not sure where the 2.0 x10^5 comes from and shouldn't you have 0.96 instead of 9.6?
[/quote]
Yes (if an onbject starts from rest and moves along a straight line) BUT you do not know the acceleration here! Just the final speed!
  • · Replies 16 ·
