Mass and weight differences on earth
  • Context: High School
  • Thread starter Thread starter mmfoley
    Earth Mass Weight
The discussion revolves around the comparison of mass and weight of an object as it moves from the surface of the Earth to its center. Participants explore the implications of gravitational forces on weight and the constancy of mass in this context.
  • One participant states that the mass of the rock remains constant while its weight decreases as it falls toward the center of the Earth, becoming weightless at the center due to the cancellation of gravitational forces from surrounding mass.
  • Another participant agrees that mass does not change and elaborates that weight decreases linearly with depth, reaching zero at the center, assuming a simplified model of the Earth as a perfect solid sphere.
  • Concerns are raised about the irregularities in Earth's density, suggesting that the gravitational center may not coincide exactly with the geometrical center.
  • One participant emphasizes that the constant mass means the rock remains equally difficult to push, despite the decrease in weight.
Participants generally agree that mass remains constant while weight changes, but there are nuances regarding the model of the Earth and the implications of gravitational forces that remain unresolved.
The discussion relies on assumptions about the Earth's shape and density, and the simplifications made in modeling gravitational effects may not account for real-world complexities.
mmfoley
Hello,
How do the mass and weight of an object at the Earth's center compare with their values at the Earth's surface? My textbook is pretty terrible for the non-physics major. I think they answer this question in eqations rather than plain English, so I'm having a hard time with this. Basically, I'm trying to figure out if I dug a hole down to the center of the Earth and dropped a rock down the hole, how would its mass and weight change from the surface of the Earth to the center of the earth.
Thanks!
mmfoley
The mass will remain constant but as the rock fell toward the center of the earth, it's weight would decrease. At the center of the earth, the rock would be weightless. The net gravitational force would be zero since the Earth's mass is surrounding the rock. The gravitational force of the Earth on one side of the rock will cancel out the force on the other side.
note: actually the rock would be weightless at the gravitational center of the Earth which doesn't exactly coincide with its geometrical center due to irregularities in the density of the earth. It's probably pretty close so for a simplified case it's OK to assume that the geometrical and gravitational centers are the same.
Originally posted by mmfoley
... I'm trying to figure out if I dug a hole down to the center of the Earth and dropped a rock down the hole, how would its mass and weight change from the surface of the Earth to the center of the earth.
The mass won't change (excluding inconsistent relativistic termonology). Weight is defined as the force of gravity exerted on an object at rest (more or less). Approximating the Earth as a perfect solid sphere, the wieght would decrease linearly with depth until it reached zero at the center (At the center of the earth, there is no pull of gravity in this model. The weight would be directly proportional to the distance from the center).
The significance of the mass not changing is that the object would remain just as difficult to push, even though its weigth would decrease.
thank you
thank you both!
  • · Replies 51 ·
  • · Replies 46 ·
  • · Replies 23 ·
15K
