Find Limit of Sequence: \sqrt{n} - \sqrt{n^2 - 1}
  • Thread starter Thread starter G01
    Limit Sequence
The discussion revolves around the convergence of the sequence defined by a_n = \sqrt{n} - \sqrt{n^2 - 1}. Participants are exploring methods to determine the limit of this sequence.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster considers using L'Hôpital's rule or the squeeze theorem to find the limit. Some participants suggest that the sequence may diverge and discuss bounding it with another function.
Participants are actively discussing the nature of the sequence, with some suggesting it diverges and others questioning the reasoning behind the proposed methods. There is a mix of interpretations regarding the behavior of the sequence and the functions used for comparison.
There is mention of using mathematical notation in the reasoning, and participants are checking assumptions about the relationships between the sequences involved.
G01
I have to find out where this sequence converges or if it converges a all:
[tex]a_n = \sqrt{n} - \sqrt{n^2 - 1}[/tex]
Now, I can't seem to find a good method to solve this. Would my best bet be to use l'hospital's rule to find the limit of the equivalent function or should I try the squeeze theorem. Thats my question. Thanks for the help.
It looks like it diverges, so show that it is bounded by a divergent sequence.
ok how the this sound as a complete solution?
An tends seems to tend toward negative infinity and diverge. I proove this by showing that a function which is always greater than it also tends toward negative infinity. I take the greater function to be the squareroot of n.([tex]f(x) = \sqrt{x}[tex]} This function tends toward negative infinity, so the corressponding sequence, and since this sequence is less than the sequence given, the sequence given will also tend toward negative infinity.<br /> <br /> Of course in my solution i'll use more mathmatical notation, but is that the correct reasoning?[/tex][/tex]
Yeah that's right. Except I think you mean the negative square root: [tex]f(x)=-\sqrt{x}[/tex]. And make sure you have in there: [tex]f(n) > a_n[/tex] for all [tex]n > a[/tex] (where you find a).
  • · Replies 17 ·
  • · Replies 34 ·
