Position Vector: Why Does it Always Point Radially Outward?
The position vector in circular motion always points radially outward due to its definition in relation to the origin. This is mathematically represented by the equation \(\vec{v} = \frac{d \vec{r}}{dt}\), where velocity is tangent to the curve, aligning with Newton's first law. The radial position simplifies calculations in curvilinear motion by focusing on three components: radial, tangential, and normal. This approach is particularly beneficial in fields such as fluid dynamics, especially when applying the Bernoulli equation.
  • Understanding of circular motion and position vectors
  • Familiarity with Newton's laws of motion
  • Basic knowledge of curvilinear motion
  • Concepts of fluid dynamics and the Bernoulli equation
  • Study the mathematical foundations of position vectors in polar coordinates
  • Explore the application of Newton's laws in curvilinear motion
  • Learn about the Bernoulli equation in fluid dynamics
  • Investigate the relationship between radial and tangential components in motion
Students of physics, engineers working with motion dynamics, and professionals in fluid mechanics will benefit from this discussion.
Swapnil
I was wondering, why does the position vector always points radially out from the center (for example, in circular motion). I figure that this is because [tex]\vec{v} = \frac{d \vec{r}}{dt}[/tex] and the velocity should always be tangent to the "curve" (because of Newton's first law).
But is there any other reason to make the position vector point radially outward??
It only points radially outward because you choose your origin at a specific point. I could just as easily decide the origin is on some pint of the circular pathway, though the math would be a tad more difficult.
Well, that is why its called the radial position. :wink:
You have three components. One is radial, one is tangent, and one is normal to the two of those. We use them because they are useful in curvilinear motion. If we used x,y,z vectors, we would have components in all 3 directions. Using radial coordinates we do not have to find components along the directions we care about. It just makes life easier. And, as you will find later in life, it is essential in fluid dynamics for the bernoulli equation.
  • · Replies 17 ·
  • · Replies 30 ·
  • · Replies 62 ·
  • · Replies 35 ·
  • · Replies 31 ·
  • · Replies 37 ·
