Phase relationship is electromagnetic wave.
The phase relationship between the electric field (E) and magnetic field (B) in electromagnetic (EM) waves is definitively in-phase for plane waves and spherical wavefronts at a distance far from the source. However, closer to the source, E and B can be 90 degrees out of phase, particularly in media with complex refractive indices. This discussion references Maxwell's equations and Faraday's law of induction to clarify misconceptions about the phase relationship, emphasizing that in free space, E and B oscillate in unison, while in certain materials, they may not. The conversation highlights the importance of understanding these relationships for accurate interpretations of electromagnetic theory.
  • Maxwell's equations in vacuum
  • Faraday's law of induction
  • Understanding of electromagnetic wave propagation
  • Knowledge of complex refractive indices in materials
  • Study Maxwell's equations and their implications for electromagnetic waves
  • Explore the derivation and applications of Faraday's law of induction
  • Investigate the behavior of electromagnetic waves in various media
  • Learn about the Poynting vector and its role in energy propagation in EM waves
Physicists, electrical engineers, and students of electromagnetism seeking a deeper understanding of the phase relationships in electromagnetic wave propagation and their implications in various media.
vebrown
What is the phase relationship between the magnetic component and the electric component of an electromagnetic field. Is it in phase, or 90 degrees out of phase. I see it both ways in a Google search ?
The electric and magnetic field oscillate in phase (i.e. when E is at its maximum, so is B, etc.), but their direction of oscillation is perpendicular.
Thanks; that's what I always thought; but I'm finding lots of resistance to that notion in another forum.
we probably should qualify that a little. for sure, in a plane wave, the E field and B field are in-phase. for a spherical expanding wavefront (the EM source is a point), at a distance that is many wavelengths away from the center point, the spherical wavefront is virtually identical to a plane wave so the E and B fields are in-phase. however much closer to the source, the E and B fields are not in-phase and, in the limit as you close in on the source, the E and B fields are 90 degrees out of phase.
the same is true for the instantaneous pressure (difference from atmospheric) and particle velocity of a spherically expanding sound wave.
Ask them to prove using Maxwell's equations why E ought to be a maximum when dB/dt is a maximum. They will quickly see the error in their ways.
Further to rbj's post I would also like to point out that waves in media (including hollow waveguides) and resonators also do not have their E and B fields in phase.
Claude.
I don't know about spherical waves, but for monochromatic plane waves in a media, the equations
\vec{E}\times \vec{k} = \vec{B}
\vec{B}\times \vec{k} = \vec{E}
still hold. Besides pointing to the perpendicularity of E,B and k, don't they also indicate that E and B are in phase?
Thanks guys; a physicist finally showed the solutions to Maxwell's equations that required an in-phase relationship and the oponent conceeded. We were having trouble confusing a radiating EM wave with an LC circuit.
This is the thread
Vern
Really Claude, you're worrying me. Did I read you right when you said that in matter, E and B (D and H) are not in phase?
Well maximum voltage occurs when the conductor is perpendicular to the field
Sorry, that was worded badly. I should have said not necessarily in phase. Materials with an imaginary component in their refractive index (typically conductors) will have E and B not in phase.
If you have Griffith's intro to EM, in section 9.4 (of my 3rd edition), it walks through this case in detail.
Apologies for the confusion (and the relatively late reply - I don't usually visit PF on weekends).
Claude.
I appreciate the reply!
Electric and magnetic field vectors are 90 degrees out of phase in electromagnetic wave propagation. Many textbooks and resources fail to make note of this. Worse even, some explanations for polarization confuse a second electric wave with the magnetic component of the first wave. Both fields are able to propagate through space without a physical medium by cyclically inducing each other. The magnitude of one vector results from the differential of the other, meaning one will be changing fastest as it aproaches zero magnitude, while the other aproaches maximum or minimum, hence, 90 degrees out of phase. By this, the vector sum of both components is constant, allowing a photon to consist of a single quantum of energy at all points in its propagation. If the fields were in phase, both would reach zero magnitude at the same point. At that point, the photon would consist of no energy at all and thus there would be no propagation. Some optical media lag one field from another to produce a phase shift. In these cases, the wave corrects it's phase back to 90 degrees by rotating it's axis of polarization, but things get more complicated at that level.
Hi Psyrick, welcome to PF!
Psyrick said:
Electric and magnetic field vectors are 90 degrees out of phase in electromagnetic wave propagation. ... The magnitude of one vector results from the differential of the other, meaning one will be changing fastest as it aproaches zero magnitude, while the other aproaches maximum or minimum, hence, 90 degrees out of phase.
This is not correct, the fields are in-phase. This is a fairly common question, here is my explanation a couple of days ago.
DaleSpam said:
Wannabeagenius is correct. They are in-phase, not 90 degrees out of phase.
If you look at Maxwell's laws in vacuum you will find that it is not quite corect that "a changing magnetic field induces an electric field". It is more correct to say "a changing magnetic field induces curl of an electric field" or in other words "a changing magnetic field (in time) induces a spatially changing electric field". When you express it correctly you immediately see that the electric and magnetic fields should be in phase.
If you look at Faraday's law of induction, you will find it supports my argument. Furthermore, if you are to dismantle my argument, you will need to explain how a photon can hold a uniform quantity of energy with ever-changing charge and both fields reaching zero magnitude at the same points.
No, it doesn't. See my explanation above.
Would you care to state Faraday's law of induction and show how it supports your position?
Indeed, I can.
The term emf stsnds for electromotive force, which is a voltage or electric potential difference capable of creating an electric current. From quantitative experiments, Faraday determined that emf induced in a coil of N loops depends on the time rate of change of the number of magnetic field lines through all the loops, or the time rate of change of the total magnetic flux. This dependance, known as Faraday's law of induction, is expressed mathematically as:
EMF = - N (ΔФ / Δt)
Where ΔФ = Change in magnetic flux through one loop
Δt = Change in time
N = Number of turns in the loop
(Wilson, Buffa, and Lou 657-659)
The EMF generated is proportional to the rate of change of the magnetic flux. (Ulaby 255)
This helps to describe a phase relationship where one field induces the other as it changes. A 90 degree phase relationship explains for how both fields can pass their energy back and forth between one another as they propagate through space. One field holds all the energy while the other aproaches zero and then cyclic repetition of induction as the field magnitudes continuously change while the total energy is conserved.
If both fields fluctuate in matched phase, where then does the energy stored within the fields go to and come from as the field magnitudes change?References:
Wilson, Jerry D., Anthony J. Buffa, and Bo Lou. College Physics. 6th ed. Upper Saddle River, NJ 07458, USA: PEARSON Prentice Hall, 2007. 657-659. Print.
Ulaby, Fawwaz T. Fundamentals of Applied Electromagnetics. 5th ed. Upper Saddle River, NJ 07458, USA: PEARSON Prentice Hall, 2007. 255. Print.
Psyrick said:
Indeed, I can.
EMF = - N (ΔФ / Δt)
Δt = Change in time
Tell me Psyrick, for a EM plane wave propagating in free space what is the number of turns in the loop, N? This expression is obviously not the general one (it is for EMF in a loop of circuit), and it is not applicable for a wave propagating in free space.
The correct general expression is:
\nabla \times \mathbf{E} = -\frac{\partial \mathbf{B}} {\partial t}
So a time-varying B field induces a spatially varying E field. For a sinusoidal plane wave the spatial variation is highest at the zero crossing and the time variation is also highest at the zero crossing. Therefore, they are in phase.
The energy goes in the direction of the Poynting vector. Remember, the fields are varying in space and time, not just time.
I have considered free space to act as a conductor in the plane as it also exibits a sub-infinite impedance.
Can you describe the phase relationship considering time as a variable of constant rate? I would like to hear more explanation about the Poynting vector. Mathematically, it is simple to understand there being a cross product of two vectors, and how it results in propagation on a third axis. But do you mean to say that this vector carries the energy of both fields at the zero-cross and delivers it from one point in space to another? If so, what form of energy does it exist in at that point? How can an energy differential be energy at a point where it does not have any electrical or magnetic potential?
Sure. Let's say that we are working with a monochromatic plane wave propagating in the z direction, and let's say that the phase between the E and B field is unknown and see if we can solve for it.
So in units where c=1 we have:
E=\left(\sin (k z-t \omega ),0,0\right)
B=\left(0, \sin (k z-t \omega+\phi ),0\right)
Now, let us plug these into Faraday's law:
\nabla \times \mathbf{E} = \left( 0,k \cos (k z-t \omega ),0\right)
-\frac{\partial \mathbf{B}} {\partial t} = \left( 0,\omega \cos (k z-t \omega +\phi),0\right)
These two expressions are only equal for:
\frac{\omega}{k}=c=1
and
\phi=0
  • · Replies 65 ·
