Calculating Wire Gauge for Length & Amp Rating
The discussion focuses on calculating the appropriate wire gauge based on the amp rating of a device and its distance from the power source. It is established that wire gauge selection is primarily based on the current draw, as indicated by American Wire Gauge (AWG) tables, rather than the length of the wire unless minimizing transmission loss is a concern. Users are directed to a relevant thread on Physics Forums for further guidance on this topic. The consensus emphasizes that voltage availability can influence wire gauge choice, but the primary factor remains the device's amperage.
  • Understanding of American Wire Gauge (AWG) standards
  • Basic knowledge of electrical current and amperage
  • Familiarity with voltage drop concepts
  • Experience with electrical installation practices
  • Research the impact of voltage drop on wire gauge selection
  • Explore AWG wire gauge tables for various amperage ratings
  • Learn about transmission loss and its significance in long-distance wiring
  • Investigate best practices for installing electrical wiring over long distances
Electricians, DIY enthusiasts, and anyone involved in electrical installations requiring knowledge of wire gauge selection based on amperage and distance.
Londmar
Need help. Is there a simple formula to calculate the gauge of wire to use vs. length for a know amp rating of a device.
I have a device I need to install a couple of hundred feet from the house and know the amps it pulls but do not know the formula to figure the best gauge wire to run to it from a breaker.
Thanks.
Thanks, that helped a lot.
No. The wire gauge you use is independent of length, unless you want to minimize transmission loss. If you've got voltage to spare and don't want to overspend on wire, just pick the gauge on the basis of the current draw - any wire gauge table will give you this data (look up AWG).
  • Poll Poll
