New Reply
Find Electric Flux through cube's side, point charge on corner
Share Thread Thread Tools
Sep1-06, 04:09 PM   #1
My problem is this,
Find the electrix flux through the top side of a cube. The cube's corner is on the origin, and is 'a' units on length. The charge 'q' is located at the origin, with the corner of the cube.
I am thinking I need a double integral. One to swipe the box in the y direction (theta), and one to swipe in the x direction (phi).
So, I know the component of the electric field perpendicular to the surface is (k*q*cos(theta))/(a*cos*theta)^2 . So I think I need to integrate this from 0 to (pi/4), then integrate again.
But how to set up the second integral is where I am confused...
Or maybe Im off track all together! Thx for any help
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Sep1-06, 05:00 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by DieCommie
My problem is this,
Find the electrix flux through the top side of a cube. The cube is centerd on the origin, and is 'a' units on length. The charge 'q' is located at the origin.
Use Gauss' law and symmetry to show that the flux through one side of the cube is 1/6th of the total flux through a gaussian sphere centred on the origin.
AM
Sep1-06, 05:14 PM   #3
Thx for the reply.
Im sorry, I mis stated my problem I will edit it.
The cube is not centered on the origin, its corner is at the origin with the charge.
So the flux through one side will not necessarly be 1/6th of the flux.
Sep1-06, 05:29 PM   #4
Recognitions:
Quote by DieCommie
Thx for the reply.
It's not 1/6 but you still can do it by symmetry. Hint: if you would surround the charge entirely by cubes, how many would you have to put there (so that the charge is completely surrounded)? By symmetry, the flux in each of those cubes will be the same and equal to the total flux over the number of cubes.
It would be quite a pain to do with an integral
Sep1-06, 07:50 PM   #5
Recognitions:
Quote by DieCommie
Thx for the reply.
You have to find the solid angle subtended by the cube face. Use Nrged's suggestion. The three faces that intersect the charge have no flux since their areas are perpendicular to the field. ([itex]E\cdot dA = 0[/itex]). It takes 8 cubes to cover a complete sphere centred at the origin of radius a, so each cube subtends 1/8th of the sphere. So each surface has 1/24th of the total flux through a gaussian sphere centred on the origin.
AM
Sep1-06, 10:01 PM   #6
I see the solution perfectaly now. Thank you all, you answered my question well.
I did infact get the double integral too, wow what a mess. But getting the double integral was satisfying.
Jun18-10, 11:22 AM   #7
can u please explain it a bit. I can't understand this thing. How would it take 8 cubes to cover a complete sphere?
Jun18-10, 11:26 AM   #8
Mentor
Quote by itheo92 View Post
Note that the cubes are arranged so that their corners are at the origin.
Feb4-12, 05:49 PM   #9
Quote by DieCommie View Post
I can do this using the gauss's law and the symmetry. Can you explain how did you do this using the integrals. I can't seems to get the correct answer when I'm using the integrals.
Feb4-12, 06:02 PM   #10
Mentor
Quote by sa_max View Post
Realize you are replying to a post made over 5 years ago.
Feb4-12, 06:42 PM   #11
Quote by Doc Al View Post
Yes I know. I was curious, and can't figure out what I'm doing wrong.I couldn't find any online resource that explains this problem using integrals. so it was worth a try.
New Reply
Thread Tools
Similar Threads for: Find Electric Flux through cube's side, point charge on corner
Thread Forum Replies
electric field of a line charge and point charge Introductory Physics Homework 14
Electric Flux on one side Introductory Physics Homework 2
Flux of a Cube with a Corner Charge Introductory Physics Homework 1
Electric flux from line charge through plane strip Introductory Physics Homework 0
Electric Flux through an Infinite Plane due to a Point charge Introductory Physics Homework 3
