What Angle and Timing Adjustments Allow Two Thrown Snowballs to Collide?
  • Thread starter Thread starter svtec
    Physics
The discussion revolves around a physics problem involving projectile motion, specifically focusing on the trajectory of two snowballs thrown at different angles and times. The original poster seeks to determine the angle and timing adjustments necessary for the two snowballs to collide at the same point.
  • The original poster attempts to resolve the motion of the snowballs into x and y components but expresses confusion regarding the final velocity at the point of impact. Some participants question the assumption that the final velocity is zero at the moment of collision.
Participants are actively engaging with the original poster's reasoning, providing insights into the physics concepts involved. There is a recognition of the need to clarify the assumptions about projectile motion and the conditions at impact. Guidance has been offered regarding the use of uniform acceleration equations to analyze the problem further.
The original poster mentions being new to physics, which may contribute to the confusion regarding the concepts of velocity and collision. This context highlights the learning environment and the challenges faced by beginners in understanding projectile motion.
svtec
In a snowball fight 2 snowballs are thrown in the same direction, but one is thrown 70.0 degrees with respect to the horizontal and the other is thrown some arbitrary distance lower. they both are thrown with a speed of 25.0 m/s.
At what angle should the one that is thrown lower be to arrive at the same point as the one that was thrown at 70.0 degrees?
How many seconds later should the lower thrown snowball be thrown to arrive at the same time as the higher one.
resolving into x and y components for the first one i get.
x initial = 0
x final =?
v initial = 25.0cos(70.0)
v final = 0 m/s
a = 0 m/s^2
y initial = 0
y final = ?
v initial = 25.0sin(70.0)
v final = 0m/s
a = -9.80m/s^2
then i get lost...
tia...
-andrew
What makes you think "v final = 0 m/s"?
i figured that when the snowball made contact with the target it's velocity would be 0.
As someone who has been hit often by snowballs before, I can reassure you that as the ball hits you, it is definitely not stationary. (You are confused with collision modelling here, I think. The velocity after it hit is presumeably zero. But not as it hits/just before it hits.)
What you want to do is to use the uniform acceleration equations in each case to work out an expression for time taken in each case for the ball to fall to the ground, and then insert this to find out the horizontal distance traveled for each, and equate the two distances to find the angle.
i am kinda confused. this is my first quarter in physics and i seem to confuse the moment before collision and the stationary component of the final velocity. i guess that is why i was enlisting the help of people that are far more superior in their understanding of physics then myself...
i'll give what you said a shot.
thanks...
-andrew
