Micro electronic circuit problems
The discussion focuses on solving problems related to capacitors and analog-to-digital converters (ADCs). A 10,000 Micro Farad capacitor with an asymmetric tolerance of +20%/-50% has a possible range of values from 5,000 Micro Farads to 12,000 Micro Farads. Additionally, a 15-bit ADC with a full-scale voltage of 10 V has a least significant bit (LSB) value of approximately 0.305 V, and an input voltage of 6.83 V corresponds to a binary output code of 2210. The discussion emphasizes the importance of understanding tolerance specifications and ADC calculations.
  • Understanding of capacitor tolerance specifications
  • Knowledge of analog-to-digital conversion principles
  • Familiarity with binary number systems
  • Basic arithmetic operations involving percentages
  • Research capacitor tolerance calculations and their implications in circuit design
  • Learn about the operation and characteristics of 15-bit ADCs
  • Study the formula for calculating binary output from ADC input voltages
  • Explore the differences between various ADC resolutions and their applications
Electrical engineers, students in electronics, and hobbyists working on circuit design and analysis involving capacitors and ADCs.
Naeem
Q1. A 10,000 Micro Farad capacitor has an asymmetric tolerance specification of +20%/-50% What is the possible range of values for this capacitor?
How do I do this problem ?
Q2. A 15-bit A/D converter has V(full scale) = 10 V. what is the value of the LSB> If the input voltage is 6.83 V, what is the binary output code of the converter?
What formula do I use here for the different parts ?
n- bit number = input voltage / ful-scale voltage VFS.
That's all I know !
These sound like homework questions. If so, they should have been posted in one of the homework forums.
-1- Do you know what +20% means? If I have 10 of something, and I add 20%, how many total do I have now? What if I subtract 20% instead?
-2- A 4-bit ADC would have 16 steps, right? How many steps does a 15 bit ADC have? If those steps span voltage input readings from 0V to 10V, what is the voltage difference per step?
a1.
range [ 5000; 12000]
a2.
berkeman's explanation should suffice...
  • · Replies 32 ·
  • · Replies 19 ·
9K
