| Thread Closed |
a ping-pong ball attached to a string in a jar of water |
Share Thread | Thread Tools |
| Sep5-06, 10:28 PM | #1 |
Consider a ping-pong ball attached to a string.
The string is secured at the bottom of a big jar, and water is used to fill the jar The ping pong ball then floats inside the water, pulling the string upwards What happens to the ping-pong ball when the jar of water is accelerated to the right? any explainations using the concepts in physics? appreciate someone who understands the dynamics well to give a reasonable analysis. Thanks |
| Sep5-06, 10:36 PM | #2 |
Just my guess...
While the jar was accelerating to the right, the ping pong ball would percieve "down" as being towards the bottom left of the jar. So it would move to the right in response. |
| Sep6-06, 01:46 AM | #3 |
Recognitions:
A pressure gradient is created in the atmosphere due to the weight of the air. That is the atmospheric pressure is higher at the bottom than at higher elevations due to the weight of the atmosphere above it. This gradient exists solely due to gravitational acceleration. Any object less dense than the local air will move in the direction of decreasing pressure. A similar situation arises due to the acceleration of the container. A pressure gradient is created in the liquid due to its acceleration. A little bit of thought should convince you that a higher pressure will exist in the liquid on the opposite side than that in which it is accelerated in (similar to people being spun inside a circular structure), that is the liquid at the front is pushing "down" on the liquid at the rear of the container due to the acceleration. The ball will then move towards the region of lower pressure in the liquid, that is in the direction in which the container is being accelerated in.
| Thread Closed |
| Thread Tools | |
Similar Threads for: a ping-pong ball attached to a string in a jar of water
| help, ping pong simulation.. pls | Programming & Comp Sci | 4 | ||
| Catapulting to the top: A ping pong story | Engineering, Comp Sci, & Technology Homework | 0 | ||
| ping-pong ball launcher | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Ping pong ball launcher | Mechanical Engineering | 5 | ||
| Ping Pong ball launcher | Classical Physics | 1 | ||
