Epsilon-Delta definition of a Limit: Question
  • Thread starter Thread starter GeoMike
    Definition Limit
The discussion focuses on the epsilon-delta definition of a limit, specifically in the context of evaluating limits at the maximum of a parabola, such as \lim_{x\rightarrow0}-x^2. GeoMike questions whether only L-\epsilon is considered when L+\epsilon falls outside the range of f(x). The consensus is that both L+\epsilon and L-\epsilon should be considered, as the limit is evaluated similarly at maximum and minimum points, and the values of x will always fall between L - ε and L + ε for any arbitrary positive ε.
  • Epsilon-delta definition of a limit
  • Understanding of parabolic functions
  • Basic calculus concepts, including limits
  • Graphical interpretation of functions
  • Study the epsilon-delta definition in detail
  • Explore limit evaluation at critical points in calculus
  • Review graphical methods for understanding limits
  • Practice problems involving limits of polynomial functions
Students of calculus, mathematics educators, and anyone seeking to deepen their understanding of limits and the epsilon-delta definition in mathematical analysis.
GeoMike
This may be a dumb question, but:
Using the epsilon-delta definition of a limit, when x is approaching the maximum of a parabola, like with: [tex]\lim_{x\rightarrow0}-x^2[/tex], obviously any value of epsilon puts [tex]L+\epsilon[/tex] outside the range of f(x). So, I take it in this case only [tex]L-\epsilon[/tex] is considered (which made sense to me graphically since you now have two points where the function intersects this line)?
I just need verification (or correction) on this because every example and problem in the two textbooks I have has given/displayed an L and an epsilon such that [tex]L-\epsilon[/tex] and [tex]L+\epsilon[/tex] both lie within the range of f(x).
-GeoMike-
Using the epsilon-delta definition of a limit, when x is approaching the maximum of a parabola, like with: [tex]\lim_{x\rightarrow0}-x^2[/tex], obviously any value of epsilon puts [tex]L+\epsilon[/tex] outside the range of f(x). So, I take it in this case only [tex]L-\epsilon[/tex] is considered?
no. you find the limit at a max/min just like you would at any other point. i think the only instance where the direction you approach a certain valuie matters is when you approcah from the right or left, not from above/below.
x always does take values between L + e and L - e for L = 0 and e an arbitrary positive number. The values all happen to be between L and L - e, with none greater than L, but this is extra information that you don't need to evaluate the limit.
  • · Replies 31 ·
  • · Replies 20 ·
