The center of Mass perfectly match the center of Force->
The discussion revolves around the relationship between the center of mass and the center of force in a system of multiple masses. Participants explore whether these two points coincide under various conditions, particularly in the context of gravitational fields and large objects.
  • Some participants propose that the center of force does not necessarily coincide with the center of mass, especially in the case of large objects subjected to gravitational forces.
  • One participant references their physics notes, suggesting that while the center of gravity coincides with the center of mass in a uniform gravitational field, this may not hold true for larger objects.
  • Another participant presents a thought experiment involving a large spacecraft, arguing that the differing forces acting on it would cause the center of mass and center of force to diverge.
  • Several participants request clarification on the definition of the center of force, indicating a lack of consensus on the terminology used in the discussion.
  • A mathematical argument is introduced, suggesting that adding an object without an applied force can change the center of mass while keeping the center of force the same, implying they are not equivalent.
  • Some participants express uncertainty about the conditions under which the centers might coincide, particularly regarding the presence of external forces.
Participants do not reach a consensus on whether the center of mass and center of force coincide. Multiple competing views are presented, with some arguing they do not match under certain conditions, while others seek clarification on the definitions involved.
Participants acknowledge the vagueness of the original question and the need for clearer definitions, particularly regarding the center of force. There are also indications of varying levels of understanding among participants, which may affect the discussion.
The center of force is same as the center of mass
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • Depends (show us on what)
    Votes: 4 100.0%
  • Total voters
deda
In a system of several masses the center of force has same position with the center of mass in the geometrical space;
Yes or No?
Please explain why!
I think the answer is no.
In my physics notes, it says, "If a body is placed in a uniform field of gravity then its centre of gracity will concide with the centre of mass. However, this may not be true for a very large object."
Well, I don't know what is one of the examples of "a very large object".
Does your notes contain equations to support that?
I think some logic can be useful.
Think an object which you can hold. Keep it steady and release it. You'll see that it does't turn around(neglecting air friction).
But think a very large spacecraft (its length is two times the diameter of the earth) falling(!) to the Earth. A much greater force is exerted to the side which is nearer the earth, so it starts to turn. Obviously CM doesn't match FM.
Am I wrong?
But did you mean where there is no gravitational force between the masses by "center of force"?
I think you are right, kishtik. The question is just too vague. Are we talking about a situation in which there is a uniform gravitational field and there are no other forces acting on an object?
Yes or No?
Please explain why!
Please defined center of force
Actually, that was something that I wanned to request from some of you. Now that I'm being ask for it I'll say:
We have a system of several masses in empty space.
There is force field in every point of space.
The force center will then be exactly that point which contains the sum of all forces each mass is subjected to.
But don't count one force twice as Newton's III sugests while summing the forces.This requires that you relate geometry with force.
My only answer will then be based on summing energies.
[tex]\sum E_i = E_{cf}[/tex]
Since for me [tex]E_i=F_iD_i[/tex] where D is the distance and F is force in D from CF then
[tex]\sum F_iD_i=F_{cf}D_{cf}[/tex]
also
[tex]\sum F_i=F_{cf}[/tex] and [tex]\sum D_i=D_{cf}[/tex]
=> [tex]\sum_{i<>j} F_iD_j=0[/tex]
is the condition for balance in the system.
Now, be soft with your critics. I'm breaking the ice here.
I'm not a native speaker of English. I only tried to say that I did't know deeply what KLscilevothma's notes were about and I would do some guessing and mental experiments etc. I am shocked as I realized what "Some logic can be useful." meant. They do not teach things like this at school or course. I'm sorry.
Okay, here goes a more "mathematical-style" proof of a physics problem I can't honestly claim I understand.
Suppose center of force = center of mass. Then take a system of such objects where this is true, and for which there is a single (nonzero) center of force.
Add an object which has no force applied to it that is not centered on the center of mass of the system. Then the collective new system has a different center of mass, but the same center of force. So the center of force and the center of mass are not the same.
Quel Est Des-probleme?
Not enough information given: you can apply a force wherever you want it.
If you're talking about gravity though, the answer is no.
  • · Replies 19 ·
  • · Replies 24 ·
  • · Replies 38 ·
  • · Replies 31 ·
  • · Replies 51 ·
