Probabilty of reliability and the failure rate
  • Context: Undergrad
  • Thread starter Thread starter scotchpie
    Failure Rate
The discussion centers on calculating the failure rate of a device with a reliability of 0.8 over 2000 hours. To determine the failure rate, one must assume an exponential probability density model, where the equation 0.8 = exp(-2000 k) is utilized. Solving this equation for the constant "k" allows for the calculation of the failure rate, which is essential for further analysis of MTBF (Mean Time Between Failures) and MTTF (Mean Time To Failure).
  • Understanding of exponential probability density functions
  • Familiarity with reliability engineering concepts
  • Knowledge of failure rate calculations
  • Basic algebra for solving equations
  • Study the exponential probability density model in reliability engineering
  • Learn how to calculate MTBF and MTTF from failure rates
  • Explore reliability metrics and their applications in engineering
  • Review case studies involving reliability calculations in devices
Students in business and engineering fields, reliability engineers, and professionals involved in device performance analysis will benefit from this discussion.
scotchpie
I am currently studying for a business qualification I am stumbling over a question.
It concerns calculating failure rate. The equation I know for this involves knowing the number of failures over a given time.
However the question is: "A device has a reliability of 0.8 over 2000 hours, calculate the failure rate."
How can I firstly work out the number of failures from this? It doesn't give any other information, ie total sample size etc. just the reliability over 2000 hours.
It's a bit of a killer as the next questions refer to MTBF (mean time between failures) and MTTF (mean time to failure) but I need to know the failure rate first before I can tackle these questions which I am confident in answering once the failure rate has been determined.
Thanks
Andrew
You are probably meant to assume an exponential probability density model. The data "A device has a reliability of 0.8 over 2000 hours" will let you calculate the single constant in the model and everything else should follow from that.
That is, 0.8 = exp(-2000 k). Solve this for "k".
  • · Replies 31 ·
  • · Replies 40 ·
