Reviewing physics I in my physics II class and having trouble
The discussion revolves around a physics problem involving projectile motion, specifically analyzing the launch speed and angle of the roadrunner and Wiley Coyote as they attempt to cross a gorge. The scenario includes parameters such as the depth of the gorge and the horizontal distance they need to cover.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the equations of motion relevant to projectile trajectories, questioning the setup of the equations used for Wiley Coyote's launch angle. There is exploration of the implications of the height from which he launches and the significance of the gorge's depth in the calculations.
Participants are actively engaging with the problem, with some suggesting alternative approaches and clarifying misunderstandings about the projectile's path. There is recognition of the need to visualize the problem and consider different interpretations of the scenario, particularly regarding the landing position of Wiley Coyote.
There is some confusion regarding the use of the gorge's depth in the equations, with participants questioning whether the calculations should reflect the height at which Wiley Coyote lands versus the bottom of the gorge. The discussion highlights the importance of accurately interpreting the problem's parameters.
FizzixIzFun
1)Wiley Coyote is chasing the roadrunner yet again. While running down the road, they come to a deep gorge, 15 m straight across and 78 m deep. The roadrunner launches itself across the gorge at a launch angle of 12 degrees above the horizontal, and lands with 2.4 m to spare. The acceleration of gravity is 9.81 m/s^2. What was the roadrunner's launch speed? Ignore air resistance. Answer in units of m/s.
2)Wiley Coyote launches himself across the gorge with the same initial speed, but at a lower launch angle. To his horror, he is short of the other lip by 0.8 m and falls into the gorge. What was Wiley Coyote's launch angle? Answer in units of degrees.
Ok, so I figured out #1. I got 20.48577875 m/s. My problem is on #2. I realized that his horizontal displacement would be 14.2 m and thus I had the equation 14.2=[Vcos(theta)][t] where V is the answer to #1. I solved that for t so I had t=14.2/[Vcos(theta)]. I then substituted that into (.5)(9.8)t^2 - [Vsin(theta)][t] - 78=0. I solved that for theta, but the value I found for theta was 83.9462306297 degrees. That can't be the right answer since Wiley launched himself at a "lower launch angle" than the roadrunner (whose launch angle was 12 degrees). I think that maybe this is one of those times where I would subtract the value of theta I found above from 90 degrees and that would give me my answer, but I'm just not sure. Your help would be extremely appreciated.
What's that "- 78" for? I assume that at time t the Coyote is at its original height (just 0.8 m short horizontally), not at the bottom of the gorge.
78 is the depth of the gorge so that you can figure out the amount of time it takes him to get from the point where he jumps to the point where he lands. it's from the kinematic x=x(initial) +V(initial)t + .5at^2
FizzixIzFun said:
78 is the depth of the gorge ...
Yes, but why are you using it in your equation? I assume that being "short of the other lip by 0.8 m" means that he returns to the starting level (y = 0, not y = -78) at x = 15 - 0.8.
(He doesn't land at the bottom of the gorge, he slams into the side!)
Ok, I'm lost. What should I do? Why doesn't he hit the bottom of the gorge?
I thought I told you what to do? :-p
To understand what's going on, draw a picture. Like any other projectile, the coyote takes a parabolic path. To just miss making it to the other side means that he hits the wall of the gorge.
In order for him to hit the bottom (at x = 14.2), he would have to jump off at a much higher angle (as you figured out!). But that's not what happens. Instead, he just misses the edge, falling short by 0.8 m.
What if he overshot the distance by 0.8m instead of falling short? In that case he would have landed on the other side at a distance of x = 15.8 m from the start instead of at x = 14.2 m. (And his y coordinate when he landed would have been y = 0.) Make sense?
Big hint: Coordinates at start of motion: x = 0; y = 0. What are the coordinates at the point where he just passes the other edge? x = 14.2 m; y = 0!
(Note: I assume that "falling short" by 0.8 m means falling short horizontally by 0.8 m. But it could also mean falling short vertically by 0.8 m.)
Oh, I see. I need to use R=([V^2]sin(2[theta])) / g. So it would look like 14.2 = ([V^2]sin(2[theta])) / 9.81 where V is the answer to #1 and I would solve for theta. Right?
Sure, you could use the range formula to solve this. But your original method in your first post was just fine--except for the "-78".
Solve it both ways!
  • · Replies 16 ·
