Contrapostive Confusion: Resolving Necessary & Sufficient Conditions
This discussion clarifies the relationship between contrapositives and necessary and sufficient conditions in logic. The contrapositive of a statement "if p then q" is expressed as "if not q then not p," which aligns with the definitions provided in the context of problems 45 and 46 from a textbook. The examples given demonstrate that being divisible by 3 is a necessary condition for being divisible by 9, and doing homework regularly is necessary for passing a course. The confusion arises from the implicit use of contrapositives in the definitions of necessary and sufficient conditions.
  • Understanding of conditional statements in logic
  • Familiarity with necessary and sufficient conditions
  • Basic knowledge of contrapositives
  • Ability to apply logical reasoning in problem-solving
  • Study the formal definitions of necessary and sufficient conditions in logic
  • Learn how to construct contrapositives for various logical statements
  • Practice rewriting conditional statements in both contrapositive and necessary/sufficient forms
  • Explore logical reasoning exercises to reinforce understanding of these concepts
Students of logic, educators teaching logical reasoning, and anyone seeking to clarify their understanding of conditional statements and their applications in mathematics and philosophy.
mr_coffee
More logic fun! contrapostive confusion, book says one thing, and yet...:Resolved:.
Hello everyone!
I'm quite confused on this issue. The directions say:
Use the contrapositive to rewrite the statements in 45 and 46 in "if-then" form in two ways.
So i first look back to see what contrapositive means. The book says:
The contrapositive of a conditional statement of the form "if p then q" is
if ~q then ~p.
Symbolically, the contrapostive of p-->q is ~q--> ~p.
I then look at the problem. Problem 45 has the answer in the back of the book.
#45. Being divisble by 3 is a necessary condtion for this number to be dividble by 9.
answer:
If this number is not divisble by 3, then it is not divisible by 9.
If this number is divisble by 9, then it is divisble by 3.
When i look at this, it doesn't follow the contrapostive form, but instead follows Necessary and Sufficient Conditions.
if r and s are statements:
r is a necessary condtion for s, mans "if not r then not s."
r is a necessary conditon for s also means "if s then r."
Why did they say contrapostive if they are not using it?
I did #46 this way:
Doing homework regularly is a necessary condtion for Jim to pass the course.
#my answer:
If Jim does not do homework regulary, then he will not pass the course.
If Jim is to pass the course, then he must do homework regularly.
Do you think that is correct? or am I not allowed to use Jim twice?
Should it be:
If not doing homework regularythen he will not pass the course.
Thanks!
mr_coffee said:
answer:
They are using the contrapositive implicitly when they give this definition. "if not r then not s" is equivalent to--is the contrapositive of--"if s then r." The definition of necessary and sufficient conditions in your book follows the contrapositive.
I would call this correct. It is a little informal with the way you use the terms "must," "will," and "does," but it gets the point across and blander language doesn't really sound right. The use of "Jim" isn't a problem. It's more grammatical than the alternative you mentioned, though if you said "If Jim is not doing homework regulary then he will not pass the course" that would also be correct.
Excellent! thanks again!
9K
