Proving Area of Parallelogram PQRS with Geometry Proof
  • Thread starter Thread starter saikishan
    Geometry Proof
The discussion focuses on proving that the sum of the areas of triangles TSR and TQP equals half the area of parallelogram PQRS, expressed mathematically as A_{TPQ} + A_{TRS} = 1/2 A_{PQRS}. To establish this proof, participants emphasize the importance of using the area formula for parallelograms and triangles. Additionally, they suggest comparing the areas of triangles PQT and PTS, as well as QTR and RTS, to simplify the computation by appropriately selecting bases and heights.
  • Understanding of parallelogram area formula
  • Knowledge of triangle area calculation
  • Familiarity with geometric proofs
  • Basic algebra for manipulating equations
  • Study the area formula for parallelograms and triangles
  • Learn how to construct geometric proofs in Grade 12 Geometry
  • Explore methods for comparing areas of geometric shapes
  • Practice problems involving area relationships in polygons
Students in Grade 12 Geometry, educators teaching geometric proofs, and anyone seeking to enhance their understanding of area relationships in parallelograms and triangles.
saikishan
PQRS is parallelogram and T is any point inside the parallelogram. Prove that delta TSR + delta TQP = 1/2 the area of parallelogram PQRS.
I know this problem has been posted earlier but there was no strong response.
Please someone help me out Grade 12 Geometry Mathematics is tough. :frown:
Assuming that delta in your post means area, so to prove that:
[tex]A_{TPQ} + A_{TRS} = \frac{1}{2} A_{PQRS}[/tex], you need the formula to find the area for the parallelogram PQRS, the formala to find the area for the two triangles TPS, and TRS.
After that, you should relate the two formulae above. What do they have in common.
Ok, try the problem again, and see if you get it. :)
Another way to do it is to compare the area of PQT to the area of PTS, and by extension compare the areas of QTR and RTS. This might require a little less computation--you just have to observe that if you measure the triangles one way (choose the base and height appropriately) they must be equal.
12K
  • · Replies 20 ·
