Register to reply
An ordered pair defined as a set
by radou
Tags: defined, ordered, pair
Share this thread:
radou
#1
Sep9-06, 11:03 AM
HW Helper
radou's Avatar
P: 3,224
Why can an ordered pair (x, y) be defined as a set {{x}, {x, y}}? Further on, (x, y, z) can de defined as {{x}, {{x}, {{y}, {y, z}}}}... I don't quite understand this.
Phys.Org News Partner Science news on Phys.org
Bees able to spot which flowers offer best rewards before landing
Classic Lewis Carroll character inspires new ecological model
When cooperation counts: Researchers find sperm benefit from grouping together in mice
Hurkyl
#2
Sep9-06, 11:08 AM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,092
What operations can you perform on ordered pairs?
Now, interpret those operations in this set-theoretic model.
Do those operations satisfy the properties they're supposed to?
radou
#3
Sep9-06, 12:15 PM
HW Helper
radou's Avatar
P: 3,224
Ok, I think I got it.. There is no order among the elements of a set, hence, since an ordered pair (or n-touple in general) is a set, there has to be a way to imply order in set notation, as well as to keep the fact that (a, b) = (a', b') <=> a=a' & b=b' true. So, from a set {{a}, {a, b}} we can 'read': the set with only one element is {a}, which makes a the first element in the ordered pair (a, b). Assuming a does not equal b, we 'jump' to the next set {a, b}, and select the element b as the second element of (a, b).
Analogically, if we have a set { {a}, { {a}, {{b}, {b, c}} } }, we see that the set with one element is {a}, which makes a the first element in (a, b, c). Let's assume a, b and b, c are different. So, we 'jump' to the next set { {a}, {{b}, {b, c}} }. Since, a and b are different, we directly jump to the set {{b}, {b, c}} and select b for the second element of (a, b, c), since {b} is a singleton. And, finally, since b and c are different, we select c for the third element of (a, b, c)... Is this a correct way of thinking?
Hurkyl
#4
Sep9-06, 03:00 PM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,092
Right; you got the idea behind it.
There is a slight technicality, though -- the set {a, {a, b}} doesn't always have two elements. So you have to take that into consideration if you want to get everything completely right.
HallsofIvy
#5
Sep9-06, 07:00 PM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,352
The whole point of "ordered pair" is that, unlike the set {a, b}, we distinguish between the two members. Writing (a,b)= {{a},{a,b}} just means that there are two members, a and b, and we distinguish between the two. Hurkyl's point about "the set {a, {a, b}} doesn't always have two elements" is that the "pair" (a,b) corresponds to the set {{a},{a,a}}. But since {a, a} is a set where we don't "double list" the same thing, {a,a} is the same as {a}. That means that {{a}, {a,a}}= {{a},{a}} which is exactly the same as {{a}}.
When talking about "ordered triples", we can think of (a,b,c) as the "ordered pair" ((a,b),c) where the first member is the ordered pair (a,b). That is the same as the set {{(a,b)}, {(a,b),c}}. But (a,b) is {{a},{a,b}} so {{(a,b)},{(a,b),c}}= {{{{a},{a,b}}},{{{a},{a,b}},c}}. Or we could write it as (a, (b,c))= {{a},{a,(b,c)}= {{a},{a,{b,{b,c}}}.
(That reminds me of the computer language "LISP"- "Lots of Insane, Silly Parentheses"!
Register to reply
Related Discussions
Ordered Sum of Sets Set Theory, Logic, Probability, Statistics 2
Partially ordered set Calculus & Beyond Homework 4
Ordered pair Set Theory, Logic, Probability, Statistics 52
Partially ordered set Linear & Abstract Algebra 11
Definition of ordered pair Set Theory, Logic, Probability, Statistics 10
