| Thread Closed |
Parachute deployment (non-instantaneous) |
Share Thread | Thread Tools |
| Sep9-06, 09:52 PM | #1 |
Here's the problem...
A car of mass 2000 kg, drag coefficient .3, frontal area 1 sq. meter releases parachute of area Pi sq. meters (diameter 2 m). The inital velocity of the car is 100 m/s. Calculate distance and velocity after 10 seconds. I know how to work this problem for instantaneous deployment. However, if the deployment is non-instantaneous, I need to make a few assumptions. The first is that the area of the parachute increases linearly with time: A(t) = A0 + kt, where A0 is the initial area of the undeployed parachute and k is the time rate of area increase. ***What should I assume for A0??? ***Is it reasonable to assume that the parachute can be deployed in 3-5 seconds? Is this too great a time interval? Too small? From this I can determine the approximate value of k (area increase per second). ***I was told I can assume the coefficient of drag remains constant. Does this sound like a reasonable model for non-instantaneous deployment? If so, I know how to find the desired values for distance and velocity. Am I on the right track??? Thanks for any input! |
| Sep10-06, 06:13 AM | #2 |
3-5 secs seems ok.
I happen to know that at terminal velocity on a parachute jump i have pulled at 5500ft, on a student canopy (large area), and been under a fully inflated canopy in secs. They train you to count the inflation before making malfunction checks, and its about 5 sec countdown. With modern chutes the slider has a big effect on the deployment time. It catches the air and slides up along the risers slowing deployment and reducing Jerk. |
| Sep10-06, 06:23 AM | #3 |
For area at t0 i would take the vehicles area only ( i.e. the drag that has allways been on the vehicle ).
The drag will be effected as the vehicle slows, but i think thats taken care of in the drag coefficient. Im not familiar with the equation for the coefficient of drag. Seems like a good start to me, same as i would do, though i would prob try and define a curve for the deployment :P |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Parachute deployment (non-instantaneous)
| Solar Panel Deployment | Mechanical Engineering | 17 | ||
| Force of Air-bag deployment. | Introductory Physics Homework | 8 | ||
| Help with rate of deployment? | General Physics | 2 | ||
| .NET Deployment Problem | Programming & Comp Sci | 1 | ||
| deployment of solar panels | Mechanical Engineering | 1 | ||
