Differential Equations Problem
The discussion revolves around a differential equation of the form d^2y/dx^2 + dy/dx - 6y = 0, along with initial conditions y(0)= 6 and y'(0)=2. Participants are examining whether two proposed functions are solutions to this equation.
  • Exploratory, Assumption checking
  • Participants suggest substituting the proposed functions into the differential equation to verify if they satisfy it. There is also mention of checking the initial conditions to determine if the functions are valid solutions.
The discussion is active, with participants providing guidance on how to approach the problem. Some have indicated that one of the proposed functions may not satisfy the initial conditions, while others are confirming that both functions fit the differential equation itself.
There is an emphasis on verifying both the differential equation and the initial conditions, which may influence the determination of the solutions. The original poster seeks assistance in starting the problem, indicating a possible lack of familiarity with the verification process.
Dao Tuat
Could someone please help me with this problem:
Consider the differential equation d^2y/dx^2 + dy/dx - 6y = 0 with the initial conditions y(0)= 6 and y'(0)=2. Determine whether the following functions are solutions:
a. y=4e^(2x) + 2e^(-3x)
b. y=2e^(2x) + 4e^(-3x)
If someone could please at least help me get started on this I would appreciate it very much
Thanks,
Dao Tuat
You need to substitute the two solutions given into the differential equation, and see if they come to zero. I don't think they're asking you to solve it directly.
Be sure to also check that the solutions satisfy the given initial conditions.
So then neither a or b are solutions, right?
Only a. is a solution because b. doesn't satisfy y'(0) = 2 (y'(0) = -8). They both fit the equation, though, as can seen below.
(16e^(2x) + 18e^(-3x)) + (8e^(2x) - 6e^(2x)) - 6*(4e^(2x) + 2e^(-3x)
(8e^(2x) + 36e^(-3x)) + (4e^(2x) - 12e^(-3x)) - 6*(2e^(2x) + 4e^(-3x))
  • · Replies 25 ·
