AZING!Acceleration Through a Curve: How to Calculate and Understand It
The discussion revolves around calculating acceleration for a car changing direction at a constant speed while navigating a curve. The problem involves concepts from kinematics and circular motion, specifically focusing on centripetal acceleration and the relationship between linear and angular quantities.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the calculation of acceleration components and question the assumptions regarding constant acceleration. There is a discussion about the necessity of knowing the radius of the curve to determine centripetal acceleration and the implications of tangential acceleration.
Some participants have provided guidance on using angular relationships to derive centripetal acceleration without a known radius. Multiple interpretations of the problem are being explored, particularly regarding the differences between average and instantaneous values of acceleration components.
There is an ongoing discussion about the implications of not having a radius value and how that affects the calculations. Participants are also considering the nature of acceleration components over time during the turn.
NotMrX
If a car gradually changes a direction of 90 degrees at constant speed of 200 m/s over a time period of 20 seconds, then what is the accelleration?
I don't know if the way I worked it was correct. I think the only assumption is that the acceleration is constant.
[tex]a_x=\frac{v_xf-v_xi}{t}=\frac{0-200}{20}=-10[/tex]
[tex]a_y=\frac{v_yf-v_yi}{t}=\frac{200-0}{20}=10[/tex]
[tex]a=\sqrt{a_x^2+a_y^2}=\sqrt{(-10)^2+10^2}=10\sqrt{2}[/tex]
Does this seem right to you?
No. Assume it is a curve of constant radius. Work out the centripetal acceleration. Is there any tangential acceleration here? Take the vector sum of both accelerations.
AM
AM
How would someone do that if the radius isn't given? I understand that
[tex]a_c=\frac{v^2}{r}[/tex]
but if there is no r value it seems hard to figure out the centripetal acceleration?
Use [itex]\theta = \omega t[/itex] and [itex]v = \omega R[/itex]
AM
AM
[tex]a_c=\frac{v^2}{r}=\frac{v^2}{v/\omega}=v*\omega=v*\frac{\theta}{t}=200*\frac{\pi/2}{20}=5\pi[/tex]
Thanks for the help. How come the other way didn't work?
Because [itex]\sqrt{2} \ne \pi/2[/itex]. Close but not the same.
You will notice that the components do not change uniformly with time - it depends on the angle. You are taking the sum of the time average of each component over a quarter turn. Averages over time will be different than the instantaneous value unless the rate of change is uniform over time.
AM
  • · Replies 20 ·
