Calculating Drop Time to Reach 90 km/h: Confirm/Deny!
  • Context: Undergrad
  • Thread starter Thread starter KingNothing
    Calculation
The discussion centers around calculating the time it takes for an object to reach a velocity of 90 km/h when dropped from rest, considering gravitational acceleration and the effects of air resistance. Participants explore various equations of motion and their applications in this context.
  • One participant claims it takes about 2.26 seconds to reach 90 km/h, using various kinematic equations.
  • Another participant calculates the time to be 2.55 seconds, assuming no air resistance and using an acceleration of 9.81 m/s², and notes that falling for 2.26 seconds results in a velocity of 80 km/h.
  • A request for clarification is made regarding the calculations, indicating confusion over the results.
  • One participant explains their calculation process, converting 90 km/h to 25 m/s and applying the formula T = Velocity/acceleration.
  • Another participant questions the use of a specific equation, suggesting that it may not be appropriate for the scenario described.
  • A response indicates that the equation used is incorrect for determining final velocity from distance and acceleration, emphasizing the need for consistency in units across equations.
Participants express differing views on the time required to reach 90 km/h, with calculations yielding different results. There is no consensus on the correct approach or final answer, and the discussion remains unresolved.
Participants assume standard gravitational acceleration but note variations in values used. The discussion highlights the importance of unit consistency in equations and the potential for confusion in applying kinematic formulas.
KingNothing
Can anyone confirm/deny that if an object is dropped (init. velocity=0) that it will take about 2.26 seconds to reach 90 km/h?
[tex]S=\frac{D}{T}[/tex]
[tex]A=\frac{V_f-V_i}{T_f-T_i}[/tex]
[tex]D=\frac{1}{2}gT^2[/tex]
[tex]V_f^2=V_i^2+2a(X_f-X_i)[/tex]
[tex]\overline{V}=\frac{V_f+V_i}{2}[/tex]
Assuming no air resistance and an acceleration of 9.81 m/s^2, I get 2.55 seconds.
Or if the object falls for 2.26 seconds, it will have a velocity of 80 Km/hr.
Can you go through it for me? It's really confusing me as to why I keep getting what I do.
Time = Velocity/acceleration
The units I used were Seconds, m/s, m/s^2
I converted your value of 90 km/hr to m/s. Divide by 3.6 to convert km/hr to m/s. 90 km/hr = 25 m/s
I simply plugged in the values into the above formula.
T = 25 /9.81 = 2.55 seconds.
Your answer wans't really that far off. What values did you use?
Just to start off, we have to assume gravity to be 9.8 in our physics class, but I don't think that can attribute to the difference. Anyhoo, what is wrong with using:
[tex]V_f = V_i + \frac{1}{2} a t^2[/tex]
If [tex]V_f[/tex]=25 and [tex]\frac{1}{2}a[/tex]=4.9 and [tex]V_i[/tex]=0, then what should I come out with, or is this the wrong equation?
It's the wrong equation. [itex]1/2 a t^2[/itex] is an expression of distance traveled under a constant acceleration for a given length of time.
Since [itex]V_i=0[/itex], your equation simplifies to [itex]V_f = 1/2 a t^2[/itex] which is not correct. [itex]D = 1/2 a t^2[/itex] when intial distance and velocity equal 0. Otherwise,
[tex]D = D_i+V_i t + \frac{a t^2}{2}[/tex]
the units on one side of the equation have to match the units on the other side. That's a good way to check for errors in an equation.
[tex]V_f = V_i + a t[/tex]
  • · Replies 53 ·
  • · Replies 20 ·
