| Thread Closed |
Designing a switching circuit |
Share Thread | Thread Tools |
| Sep15-06, 10:42 AM | #1 |
Hello All,
Can someone give me some suggestions for a chip that can drive some high frequency mosfets to create an AC square wave? I am designing a circuit that pulses the voltage from a capacitor into some coils I am working with but I need the square wave to be AC and not DC. I want to use mosfets to do this but I'm not sure how to switch it so that it will be AC. Also, I am working with a rather wide frequency range for my experiments so whatever I come up with needs to be very adjustable (1KHz-7MHz). Even if I could come up with a couple of separate controllers that will cover the wide range, that would be fine too. I *think* that a 555 timer would work for the lower frequencies but what abut the higher ones? Thanks, Jason O |
| Sep15-06, 01:14 PM | #2 |
Mentor
You could just to a quick and dirty inverter RC oscillator. Use something like an HC14 Schmidt trigger inverter, and put a resistor from its output to its input, and put a cap on its input to ground. Or you can use 3 inverters in a row (still just the one RC) to make it work a little cleaner. You adjust the RC time constant to get the frequency.
| Sep15-06, 01:31 PM | #3 |
I don't really know what an "AC" or "DC" square wave even means to you.
- Warren |
| Sep15-06, 06:38 PM | #4 |
Designing a switching circuit@berkeman Thank you very much for the information. I've never heard of a HC14 Schmidt trigger inverter. Could you give me some more info on it or maybe a good source link? Also, it would be very helpful if you could make a basic circuit diagram of what you are describing. Thank you, Jason O |
| Sep15-06, 07:47 PM | #5 |
are u making a stun gun?
It's tough making a clean high frequency signal due to capacitance in the wiring and leads. if a signal goes from -5v to 5v, isn't it the same as 0 to 10v? |
| Sep16-06, 03:36 PM | #6 |
No I'm not working on any kind of weapons stuff. I'm experimenting with different obscure electrical effects such as the Barkhausen Effect, and electrostatic induction. Some of my tests involve the use of medium to high voltage spikes at specific frequencies. I will be experimenting with both the AC and DC square waves but so far, the AC ones seem to have the most pronounced effects. Thanks, Jason O |
| Sep17-06, 11:06 AM | #7 |
Mentor
http://www.fairchildsemi.com/an/AN/A...r%20schmidt%22 |
| Sep21-06, 08:28 PM | #8 |
Hi berkeman,
Thanks for the correction about the DC offsets. As for the control circuit. I *think* I found a setup that will work. I'll post the circuit diagram for it once I finish testing it out. Thanks for all your help. - Jason O |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Designing a switching circuit
| Designing a circuit from a transfer function [linear control] | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Designing a circuit | Engineering, Comp Sci, & Technology Homework | 4 | ||
| Switching d | Differential Geometry | 1 | ||
| 5V Switching Regulator | Electrical Engineering | 13 | ||
| Switching help | Electrical Engineering | 6 | ||
