Adiabatic process btwn 2 containers
The discussion focuses on the calculation of final equilibrium pressure in an adiabatic process involving two connected cylinders. The initial approach using the formula PiV1gamma = Pf(V1 + V2)gamma was incorrect. The correct method is PiV1gamma = PfV1gamma + PfV2gamma, which accounts for the change in moles of gas when the valve is opened. This scenario exemplifies adiabatic free expansion, where no work is done, and total internal energy remains constant.
  • Understanding of adiabatic processes in thermodynamics
  • Familiarity with the ideal gas law and its applications
  • Knowledge of the concept of internal energy in thermodynamic systems
  • Basic grasp of the principles of gas expansion and pressure-volume relationships
  • Study the principles of adiabatic free expansion in thermodynamics
  • Learn about the derivation and applications of the formula PVgamma = constant
  • Explore the concept of internal energy and its implications in gas systems
  • Investigate real-world applications of adiabatic processes in engineering
Students of thermodynamics, engineers working with gas systems, and anyone interested in the principles of adiabatic processes and their applications in real-world scenarios.
Kenny Lee
Two cylinders of equal volume are connected by a valve. We are given the pressure for one of them, and then told to find the final equilibrium pressure after the valve is opened. Adiabatic process may be assumed.
I know the solution, but not sure why its that way... initially, I tried PiV1^gamma = Pf(V1+V2)^gamma. But the correct method is: PiV1^gamma =PfV1^gamma+PfV2^gamma.
Someone please tell me how the latter is valid. It seems to me that it violates the basic formula PV^gamma = constant.
PV^gamma is constant for an adiabatic process if n is constant. Opening up the chambers changes the number of moles of gas in the first cylinder. That which stays constant for the two chambers together is total internal energy.
Edit: hmm, I'm assuming that this was an example of "adiabatic free expansion." Was there total vacuum in the second cylinder? IF so, then in this situation, no work is done when the gas expands (you see, there is no piston involved). That's why internal energy remains constant.
thanks, I get it now. Hey, youve helped me out quite a few times already. Just so you know, I genuinely appreciate it
